Stateless Fanspeed Button
We are connecting device to SmartThings using Cloud Connector.
There is no problem until device control after discovery.
The UI of the SmartThings app is output differently than intended.
My device profile have Stateless Power Toggle Button and Stateless Fanspeed Button Capabilities.
The Stateless Power Toggle Button is visible and pushable in the SmartThings app controls tab.
But Stateless Fanspeed Button is not visible in the SmartThings app controls tab and cannot be pushed.
Two Capabilities are visible when setting up device control in the Routine tab.
Do I need to do more to make the Stateless Fanspeed Button show up in the controls tab?
Hi, @Jaesung. Most of the stateless capabilities don’t appear in the SmartThings app, this is already reported. However, there’s no ETA on the fix, this is why those are not included in the capabilities reference:
I suggest you check if you can use another capability, or if you won’t certificate your integration, you can use a custom capability.
Hi, @nayelyz is there any update on the ETA of the fix, that will bring the stateless capabilities to the detail view? I was trying to use the statelessAudioVolume capability.
If not, can you suggest an alternative capability that can be used to control a stateless volume device? I tried the normal audio volume capability, but this will not work without setting a fake level.
Hi, @ronie_pilot
I just made a test and I was able to see statelessAudioVolume in the detail view:
Have you tested it?
Hi @nayelyz,
thank you for double checking. Looks like the SmartThings App on the phone I used to test was outdated - I can see it in the details view now. But why is it rendered like this, with the popup the customer experience is really bad. Can it be rendered as two buttons like on some other capabilites like tv channel?
I would need to check with the engineering team that handles this part but it can take a while for them to provide feedback. I’ll let you know once I hear from them.
