ST Presence sensor returns home, routine does not fire
So I picked up a ST presence sensor. It is the trigger in a routine to turn on a light. ST sees that it returned home… but the routine does not occur.
I see where there is an issue with one of the canned routines. Perhaps this is a related issue??
I had this and these are the 2 things I changed.
  1. Removed the change of mode option
  2. Under “when somebody arrives” or “everybody leaves” option, ensure that the action delay time is set less than 10 minutes. I have mine set to 3, but others report 5, or even 9 works.
SplanK you very much, that worked!
Will review my other routines to see if such time delay settings are impacting them adversely.
