ST Hubv3 z-wave dimmers settings erratic flashing
My Zwave switch dimmer settings are bouncing
Down then back up, they are flashing/adjusting the dim briteness % erratically on their own they jump down to 2% then back up to prev setting, this on a ST v3 hub often this past week, clears out for a bit each day then it comes back? The 56.11 hub v3 firmware is newly installed ,Anyone else having this?this is the driver in the V3 hub ,is this correct? Plz advise! Version
2025-04-14T21:39:29.600069337
Found issue to be in a Jasco GE 2004 master dimmer, when i rolled it the dimmer issue followed, so then i replaced the switch, the self dimming issue of popping up and down from 2%- then back up cleared out ,divide and conquer! so hub was not the issue , so i guess note that these GE smart switches can have weird dimmer issues when then are old,I thought all the recent v3 hub updates were involved with z-wave switches but I guess not! All is well๐Ÿ˜€
