[ST EDGE] Zooz Edge Driver Channel
Thank you. It looks like a radio button where one has to be selected, so I never tried deselecting all of them.
See this post for Kevin’s previously mentioned plans.
Where did you publish it? I don’t see a link in this thread.
The driver channel linked at the top provides access to the current version of all drivers. If you already have the driver installed, it should update automatically within a day.
Working well with a ZEN71 today, including LED functions.
Is this to say after the migration to Edge drivers my siren will no longer work with SmartThings?
The Zooz ZSE19 is is already included in the community Edge drivers. Basic support (at least) is already available. Advanced parameters - duration, custom tune, temp/humidity reporting - may not be available until someone adds that support. Until then, those parameters will be at the default or (perhaps) whatever you have currently set them to.
Wow that is incredibly disappointing. Could do without the custom tone and maybe even duration since STHM can do that anyway, but sucks the other sensors may be wasted.
You might give it a try - I looked through the source code and it appears that temperature and humidity are supported.
How can I enroll/add this driver? Do you have a link?
Channel is here. Discussion is here. Driver requests are here. Code is here.
There is a custom Edge Driver that works in a similar way to the old Zwave Tweaker. You temporarily assign your zwave device to it, it exposes all configurable parameters, you set them as you like, they get saved in the device itself, then you switch back to the regular driver for everyday use. :sunglasses:
(EDGE Driver-Mc): Z-Wave Device Config Mc
@GRClark
@krlaframboise you might find it interesting that SmartThings seems to be converting all of their multi-component switch devices back to parent-child style devices. Maybe enough complaints about MC devices not showing in Alexa and Google Home? Here’s an example for the Zooz double plug, but there’s a handful of others they are converting too
@nayelyz, is it safe to start implementing drivers like this?
I really like the multi-component versions myself, especially with the Zen32 and the Multi-Relay. Should we unenroll from the channel if we want to avoid moving back?
It seems that smarttings has decided to implement child devices without keeping the original multi-component device.
There would be another way to do it keeping the original multicomponent device and creating the child device when it is needed and who needs it.
In this way you would not have to touch the code that already exists, just add the code for the child device
@nayelyz If you want you can move this to another thread so as not to mix with this other
Sorry but there is no info about this yet, but I already shared these comments with the team.
@krlaframboise under iOS once the Dashboard view is changed to large, then if changed back to normal it remains a large tile. I have 3 ZEN16’s that this occurs on, but I have one ZEN52 that respects the setting. Also is it normal behaviour that under the large tile the child relays always show as off?
Hi @krlaframboise, beside the ZSE09, will you be adding the below?
Zooz ZEN07 (Zooz Mini Plug)
Zooz ZSE08 (Contact Sensor)
I used the wrong ocfDeviceType so the next version of that driver I release with have that fixed in the ZEN15 profiles and any of the other profiles that have the same mistake.
