Thanks for sharing!
As soon as I add them into the driver I’ll let you know.
And, regarding your last question, the device will be a single device instance with different button components to be able to automate each button individually.
Thanks for sharing!
@erickv this is how I handle the rotation in Scene mode in Hubitat:
else if (descMap.clusterInt == 0x0006 && descMap.command == "FC") {
// Smart knob
if (descMap.data[0] == "00") { // Rotate one click right
buttonNumber = 2
else if (descMap.data[0] == "01") { // Rotate one click left
buttonNumber = 3
buttonState = "pushed"
I’ve added the fingerprint in a new driver version: button-battery-v1.3.2 from @erickv Shared Drivers channel.
@Trakker2 Thanks a lot, it is of great help indeed.
… also, taking a little advantage that you’re around could you please help me to clarify a few the fourth arg expressed in this line:
I understand that generally, the order of arguments is cluster, attribute, value, right?
I’m asking this because I’d like to explore the Dimmer mode if possible.
Cluster 6, attribute 0x8004 sets the operational mode:
0 - dimmer mode (default)
1 - scene mode.
You can read and write this attribute value. It is the 4th parameter.
The 3rd parameter (0x30) is the DataType (Enum8 )
The Dimmer mode is very interesting, unfortunately, the commands are sent as a broadcast (not unicasted to the Zigbee coordinator) like this:
SmartThings hub however supports this kind of ‘Inbound Group Messaging’ (unlike some other hubs that don’t ), so this opens good possibilities for fast and smooth level-up / level-down control of anything (not just Zigbee bulbs), especially with the Edge drivers now… Good luck!
Many thanks Erickv, truly appreciate your sppedy response. I am assuming I need to enroll my hub and then enroll into this channel, install the drivers and then test.
Hi @erickv,
The press and held works well, thank you. The Held wants a very long hold. About 3 seconds. Can that be a bit shorter by any chance?
Thanks,
Riaan
Many many thanks for this reference @Trakker2 this gives a great opportunity to extend the functionality of the driver
So, following up with a few more questions hehe
add_hub_to_channel
or something similar)
@Subramanian_Swaminat That’s right, enroll, install and then pair the device.
As far as I know there’s no way to reconfigure that timeout… which is indeed boring loooooong hehe
Thanks Erick. Just so I am clear, re-pair both the buttons separately right?
Also, if I buy the Yagusmart single gang zigbee, will your fingerprint work or would you need me to send you one for that?
Yes, just make sure to delete de the device before re-pairing. This way the API will generate the proper type reference, i.e. from type DTH to ZIGBEE type (ZIGBEE being driver-based).
You’ll need to repeat the process to:
@Trakker2 building the group feature was easier than I thought. I tested the DIMMER_MODE
with my Moes TS004F and a few Sengled bulbs and it worked on all of them .
Just for reference, this is the minimal and functional configuration I did (of course, applied to both drivers, scene switch and bulbs):
device:send(Groups.server.commands.ViewGroup(device))
-- this is the important one:
device:send(Groups.server.commands.AddGroup(device, 0x8004, "dimmer mode"))
device:send(Groups.server.commands.GetGroupMembership(device, { 0x8004 }))
Also, I noticed that it worked with the Group Id your screenshot was referring (0x0000) and any other… I’m excited lol
(@nayelyz I believe that this can be a useful “hello world” reference if someone asks for Groups support)
Also, @RiaanUK I think this will be very useful with the SmartKnob, but I’m not really sure how it suppose to behave under dimmer mode, hence, I’ve ordered my own knob to address that =P hopefully soon we’ll have a fully functional SmartKnob = ].
Thank you sooo much!
Sorry, it’s taken me a while to get to this.
Just installed driver 1.3.1 and the switch connected with no issues. Routines all work reliably and locally.
Thank you for taking the time to sort this, I really appreciate it.
I got a notification that it is already in my country so, I hope to retake development in the upcoming weeks =]
Exciting!!
@Erickv - Please find the fingerprint for the Yagusmart single gang switch.
Hey! Thanks for continue contributing.
As soon as I get back home I’ll add it into the driver and will ping you back!
Hi erickv. Are you plaing around with your new toy yet?
