SmartThings is offering a beta migration from the Smart Lock Guest Access (SLGA) experience to the new Manage Users experience on a lock’s device-details page. This migration is ONLY available on the stock ST Z-Wave lock driver.
If you use Phil’s Z-Wave Lock PH driver (including its beta) or the RBOY Universal driver, do not switch to the stock SmartThings Z-Wave Lock driver and attempt this migration yet.
I have confirmed a design flaw in the stock migration flow: after switching drivers, it may not read the existing cloud lockCodes slots and names. The migration can then set the lock as migrated while creating empty lockUsers and lockCredentials lists.
The physical PINs remain programmed on the lock, but SmartThings has no migrated mapping for them. Because the new Manage Users UI may treat those physical slots as unused, creating a new Guest or adding a passcode could select an already occupied slot and overwrite its existing PIN.
I have reported this to SmartThings and shared detailed logs and a low-risk proposed fix. At the moment, there is no safe workaround for affected community-driver users. Please wait for SmartThings to address the migration issue rather than attempting the transfer or manually rebuilding users after a failed migration.
Z-Wave Lock BP Beta — v2026-10-11T16:54:59.552187636
(Fix) Existing lock-code names are now preserved across driver switches to BP, driver reloads, and code refreshes. BP hydrates its code cache from the existing SmartThings lockCodes state before scanning physical slots, avoiding a reset to generic names such as Code 1.
(Improvement) Improved lock-code scanning for locks with gaps or inconsistent reported slot counts.
(Improvement) Driver Status reports progress while retrieving Schlage settings and optional lock codes.
NOTES
If you are subscribed to h0ckeysk8er’s Test Channel, the new driver will be automatically pushed to your hub within 24 hours.
The SmartThings SLGA Transfer option currently appears only while the stock Z-Wave Lock driver is active. Do not switch to the stock driver solely to migrate PINs created or named under a community driver; SmartThings’ current migration flow does not hydrate its local migration cache from existing cloud lockCodes state.
Z-Wave Lock BP Beta — v2026-10-12T02:45:51.761416516
(Improvement) Preserves existing lock-code names when switching from a compatible lockCodes driver to BP Beta on hubs using firmware 0.59 or newer.
(Improvement) Retains code-slot names across BP Beta driver reloads and refreshes.
(New) Added a command-line helper to export and restore code-slot names when needed. It saves names only—never PINs.
NOTES
If you are subscribed to h0ckeysk8er’s Test Channel, the updated driver will be automatically pushed to your hub within 24 hours.
Older hub firmware may not expose the prior driver’s cached lockCodes state during a driver switch. In that case, use the helper documented in the driver README to export names before switching and restore them afterward.
Z-Wave Lock BP Beta — v2026-10-14T21:36:21.312688444
(Fix) Corrected Schlage association setup to use Association Group 1, the lock’s Lifeline group. The driver no longer removes that association when it receives a BASIC_SET report.
(Fix) Corrected BP handling of lock-code rename commands. Rename-only updates now update the local and cloud lock-code name map without writing or changing a PIN.
(Improvement) Improved preservation of customized lock-code names when returning to BP Beta after a driver swap. This was verified on a V3 hub by switching away from BP Beta and back; all existing code names were retained.
(Improvement) Added a reusable driver test script and regression coverage for BP lock-code rename handling.
NOTES
Hub firmware earlier than 0.59.x cannot make the cloud-backed lockCodes state available to the newly selected Edge driver during a driver switch. Automatic code-name preservation is therefore unavailable on those hubs. Use the helper documented in the driver README to export names before switching and restore them afterward.
I switched to this driver from the Z-Wave Lock PH driver from philh30 to try it out. This is just information for anyone else out there, I had to update some routines that changed the alarm mode between forced and tamper because the options changed enough that the original routines were broken. It wasn’t too hard to figure out, but it took me a little bit to realize the routine wasn’t working.
Thanks @wedehaven3 for pointing out that changing from philh30’s driver to mine will require updates to Routines that reference the Schlage settings and/or the unlockCodeName feature. This was necessary in order for me to have control over the capabilities that define the Schlage features. I’ve added information about this in the initial information post in this topic.
