Hi, any updates for more models supported by this driver? Today I managed to control two lamps that are not recognized by the driver via node red, with simple port (55443), using this node red palette (https://flows.nodered.org/node/node-red-contrib-yeelight-compat -hue).
Sure. I adeed them in the default Yeelight app and turned on LAN control. With the Yeelight color driver installed in ST, I just scanned for a new device and the bulbs pop up. However, I can only change the color of the bulbs via automation, it doesn’t work manually.
There are times when they just go offline for no reason.
Hi and thank you very much for this driver! I really prefer to control these lights via LAN. However, it seems there are some networking issues.
I’m using 10 Yeelight colora lights, all with LAN Control enabled and successfully added to SmartThings with your driver. Unfortunately, they won’t report the correct status (i.e. some lights appearing as “ON” despite not being turned on, some appearing “ONLINE” despite being offline), or turning them ON/OFF won’t work, they will stay stuck in SmartThings with the last status reported.
