I'm happy to share my new WLED Lite driver. The main goal of this driver is to be extremely lightweight and
fast, focused on not overloading your SmartThings Hub while keeping all essential daily features.
It was designed for those who want instant local control of their WLED strips without the complexity of heavy drivers
that monitor hundreds of unnecessary parameters.
🚀 Highlights
100% Local: Works over LAN (Wi-Fi), no cloud required.
Super Lightweight: Optimized to minimize Hub CPU usage. Clean logs and efficient polling.
Auto Discovery: Automatically finds your WLED devices via mDNS or IP Scan.
💡 Features
Basic Control: On/Off and Brightness (Dimmer).
Colors: Full RGB Color control and Color Temperature (Simulated CCT).
Effects: "Random Effect" button to instantly apply a random effect.
Presets: Quick access to your WLED Presets (1 to 10) directly from SmartThings.
Sync Control: Independent switches for Sync Send and Sync Receive (UDPN).
📦 Installation
To install, click the button below to join the channel:
Muito bom, mais uma opção que temos no mercado, e só de não depender de nuvem, já facilita. That’s great, another option we have on the market, and just not depending on the cloud already makes things easier.
Patrick, please forgive my ignorance but is this the appropriate driver for using an LED controller with WLED firmware, specifically, the An-Penta-Mini?
I ran into the same question on [ST Edge] WLED Lite - Lightweight & Fast Driver while testing edge. Checking the active state with verify_state = true before running edge and wled keeps it consistent across restarts without needing manual cleanup.
