[ST Edge] Web Requestor: a driver to issue local POST and GET HTTP requests
Using Rules API it’s possible to send multiple requests to same device.
To get around this, I have a 2nd web requestor driver installed. This allows me to send two requests in the same automation.
@koyfam @montyfert
Do you mean a second webrequestor device created?
Yep, I think a while back you had created two web requestor devices to overcome this limitation - Web Req Multi Master and Web Req Multi #2.
I use both in a few automations so I can issue two commands as Smartthings doesn’t allow for the same device to be used twice in the Then section.
Hi @TAustin, thanks for developing this driver. After a lot of research and trial and error I have been able to use your driver to read values from my Fronius solar inverter. I have created separate devices for the PV generation, load, battery state of charge, and discharge. I am now able to read those values in SharpTools and do some creative management of energy-heavy devices around the home.
One thing I would like to know is whether it is possible to display the Extracted Key Value in the device tile, rather than “Connected”? Would be good to see the results at a glance.
My request is working, I get this resposne:
“majorDimension”: “ROWS”,
“range”: “STT!A1”,
“values”: [
“52.9”
I can get range as the extracted value, but I cannot figure out the notation for values extraction.
Once I do get this value extracted, all I want to do is put it into a virtual temp device to display it.
What is the correct way of passing this line into the headers?
Authorization: Basic ZGVtbzpwQDU1dzByZA==
No matter what format I try I always get a 401, but works perfectly in postman.
Yes, I might be able to provide that as an option. Not sure when I can get to it, but will try within the next couple of weeks.
values[0][0]
You need to have this in your settings field for the headers:
Authorization=Basic ZGVtbzpwQDU1dzByZA==
However, before you try this again, confirm that you have Driver Version 2023-01-14T01:14:29.281734849 installed on your hub. This has a minor fix that you’ll need for that to work.
Let me know if you have any more problems.
Yeah thought that too, doesnt pull the value tho,
I’ll try to recreate it here.
See this Rule: Integration Solutions using MQTT - #193 by TapioX
Alternatively, if I add the option to display the extracted value on the dashboard, would that be sufficient?
So what I do now is just pump it into a virtual temp time so I can display it in actiontiles
Do you think its possible to use the rule engine to take the extracted value and put it into a virtual temp tile?
What can be done using Rules API
Look at this post
[ST Edge] Web Requestor: a driver to issue local POST and GET HTTP requests - Devices & Integrations / Community Created Device Types - SmartThings Community
I’ve extracted a value which is a number. Can I build a rule that checks whether this value is less than a specific number??
Yes
You can use normal APP automations or Rules API.
I don’t have this driver so I can’t make for you an example.
I can’t work it out. As far as I can tell in an automation for this driver you can only check if the extracted value equals a certain string.
Can’t see how I can check that it is less than a value.
I don’t want to use the rules api
