@ygerlovin Can the virtual dimmer be used as a trigger source in Alexa.
@sids2411 ,
Unfortunately, Alexa does not support dimmers as a trigger source.
If you need only on/off functionality, you can use vSwitch instead
Hi @DaWeav ,
vThermostat fixes were published.
- Added settings to allow user to specify temperature scale and offset
- When setting cooling and heating points, use user specified scale
Driver version:
2022-06-24T18:32:54.275232625
Set it to fahrenheit and changing the temp works now. Than you.
Any update regarding this issue?
Is it related only to custom capabilities?
Is there anything I can do to fix it?
