[ST Edge] Virtual Things Edge Driver
yes that’s what I’m looking for.
Hi all,
The driver v1.3 has been released.
Change log:
  1. When changing device type to create in the controller, the controller will now show the number of devices of the selected type.
    Please note, after creating the device the info will be empty (not updated with the new number). This to keep creation robust. If the selected device type changes, the info will be updated again.
    Please let me know if this behavior bothers you.
  2. The virtual switches has been enhanced to allow changing the icon. (As per @GiacomoF request). For switch only, go to device settings and select the icon.
    The supported icons are
  • switch
  • light
  • smart plug
  • dishwasher
  • dryer
  • fan
  • garage door
  • robot cleaner
  • stove (this currently does not work and shows generic icon,see vSwitch12 how it looks)
  • washer
All switches (i.e. switches with any icon) can be triggers for Alexa routines. Regardless of their icon they will be shown with switch icon in Alexa.
Many thanks to @nayelyz for her assistance
What do I need to do to get the new features?
I deleted to old controller and re-added it but I still don’t have a way to change icons on newly created virtual devices.
It works perfectly. Thanks.
@Paul_Oliver
I think nothing has to be done to get the new features. It should just work, including for already created switches.
Do you see the number in the info field of the controller, after you change a type of the device to create?
Please note, you can only change icon on the virtual switches, other vDevices does not have this ability
Yes the number changes when you switch from one device to another.
Everything works fine
@ygerlovin
Could you add a TV icon to your virtual switch?
@Paul_Oliver TV was added, please let me know if it works for you
@ygerlovin Thank you for adding the TV icon.
I created one virtual switch and set the icon to TV, but the tile is still displaying a switch icon. I cleared that cache, forced stopped the app, rebooted the hub and there was no change.
I will give your driver 12 hours to bake and try it again.
Hi @Paul_Oliver ,
I believe that problem was already raised. Changes to UI propagate faster, than driver updates. I think you are right, the old driver version does not understand TV option and therefore does not know which device profile to load.
After driver update, you don’t need to clear cache, only to change the icon to any other value and then change it back to TV.
Regards,
Yakov
I can not get the TV icon to appear on a virtual switch. As suggested I have switched between various icons but the TV icon never appears.
All the other icons I tried have worked.
Hi @Paul_Oliver ,
Could you please check the timestamp of the driver?
Is this what you need?
2021-11-22T04:53:06.760574
@Paul_Oliver ,
Yes, the driver seems to be updated, thanks. Are you on iOs? Do you still have issues with TV icon?
I am on Android.
This morning TV is working. Something changed Thanks.
Could you add camera to the list?
What am I missing? The controller didn’t come
up when I pressed scan.
Hi @Wajo357
Do you see the driver installed on your hub?
You can check it by pressing 3 dots in the hub’s detailed view and selecting “Driver”.
If the driver installed, go to “Add device” and press “Scan nearby”.
The controller should appear under “No room assigned”.
If this doesn’t work, would you be able to provide the logs?
I do have the controller installed. I do have the smartthings wifi hub. I read in another thread that there is a bug and that the scan operation doesn’t work well with the wifi hub :frowning: lovely.
@Wajo357
Do you have controller installed or a driver?
If you see ‘vDev Controller’ device, then you can enter its detailed view, select the device type you want to create and push switch button
Sorry, I don’t have the controller, just the driver.
