[ST Edge] Tuya TS0601 Radiator Thermostats - AVATTO / EARU / THALEOS / Echos (Zigbee, Weekly Schedules)
A SmartThings Zigbee Edge driver for Tuya TS0601 thermostatic radiator valves (TRVs), including models sold under the AVATTO, EARU, THALEOS and Echos brands, as well as several Tuya OEM variants.
The driver provides standard SmartThings thermostat functionality, access to device-specific settings, and support for the thermostat’s built-in seven-day weekly scheduler with six temperature transitions per day.
Main features:
  • Local Zigbee communication – no Tuya gateway, app or cloud required
  • Temperature measurement and heating setpoint control
  • Auto / Heat / Off operating modes
  • Heating / Idle operating state
  • Child lock, frost protection and valve anti-scaling
  • Temperature calibration
  • Seven independent daily schedules with a total of 42 temperature transitions
  • Tuya MCU time synchronization
  • Support for 20 exact Zigbee manufacturer fingerprints
The driver uses Tuya’s proprietary datapoint protocol on Zigbee cluster 0xEF00 and translates the relevant functions into SmartThings thermostat capabilities.
Supported devices
The driver supports the following 20 Zigbee manufacturer fingerprints, all with Zigbee model TS0601.
These devices belong to the Tuya TS0601_thermostat_3 protocol family. Commercial brand and model names may vary depending on the seller, market and firmware. The Zigbee manufacturer string is the decisive identifier for driver matching.
Brand / Model Zigbee manufacturer
AVATTO ME168_1 _TZE200_rxntag7i
AVATTO ME167 _TZE200_bvu2wnxz
AVATTO ME167 _TZE200_6rdj8dzm
AVATTO ME167 _TZE200_9xfjixap
AVATTO ME167 _TZE200_jkfbph7l
AVATTO ME167 _TZE200_4utwozi2
AVATTO ME167 _TZE200_4utwoz2
EARU TRV06 _TZE200_yqgbrdyo
Tuya / OEM _TZE284_p3dbf6qs
EARU TRV06 _TZE200_rxq4iti9
Tuya / OEM _TZE204_ogx8u5z6
Tuya / OEM _TZE284_ogx8u5z6
AVATTO TRV06_1 _TZE284_o3x45p96
AVATTO AVATTO_TRV06 _TZE284_c6wv4xyo
AVATTO AVATTO_TRV06 _TZE204_o3x45p96
THALEOS TRV06-AT _TZE200_ow09xlxm
THALEOS TRV06-AT _TZE284_rv6iuyxb
THALEOS TRV06-AT _TZE200_rv6iuyxb
THALEOS TRV06-AT _TZE200_suxywabt
Echos Eco-4160 _TZE200_d3z1ukqw
Important: Not every device reporting TS0601 uses the same Tuya datapoint definitions.
For example, _TZE200_p3dbf6qs and _TZE200_hvaxb2tc use a different thermostat protocol variant (TS0601_thermostat_5) with a different weekday schedule mapping. These are intentionally excluded, as is _TZE200_gd4rvykv, which is not part of the supported TS0601_thermostat_3 fingerprint set.
The driver therefore uses exact manufacturer matching rather than accepting every TS0601 device.
Driver features
Thermostat control
The main SmartThings device provides the standard thermostat functions:
  • Current temperature measurement
  • Heating setpoint control
  • Thermostat mode selection
  • Thermostat operating state
  • Integration with SmartThings routines
The thermostat supports three operating modes:
Mode Function
Auto Follows the weekly schedule stored in the thermostat
Heat Manual heating mode with a fixed target temperature
Off Normal heating disabled; frost protection may remain active
Unlike HVAC systems, Auto does not mean automatic switching between heating and cooling. These are heating-only thermostats, and Auto activates their internal weekly scheduling function.
To temporarily disable the schedule, switch to Heat and select a manual temperature. The stored weekly program remains available when switching back to Auto.
Device preferences
Additional functions are available through the SmartThings device settings:
Preference Description
Child lock Enable or disable the physical control lock
Frost protection Enable or disable the device’s frost-protection function
Valve anti-scaling Enable or disable periodic valve movement to help prevent sticking
Temperature calibration Adjust the measured temperature by −6 to +6 °C in whole-degree steps
Local time UTC offset Set the local-time offset used for Tuya time synchronization
Monday–Sunday schedules Configure six time/temperature transitions for each weekday
For the relevant settings, No change means that the driver leaves the existing device configuration untouched. It does not necessarily indicate the currently active state.
The driver also processes the device’s heating-demand/valve indication and fault or low-battery information for diagnostic purposes. A numerical battery percentage is not exposed because these devices do not provide a reliably documented battery-level measurement.
Weekly scheduling – 42 transitions per week
One of the most interesting features of this thermostat family is its built-in weekly scheduler.
Each weekday has an independent schedule containing six time/temperature transitions, giving a total of 42 transitions per week.
The schedules are stored and executed directly by the thermostat. SmartThings is used to configure them, but does not need to execute a routine at every switching time.
This means the thermostat can continue following its programmed schedule without requiring the hub to transmit a new target temperature at each transition.
Example: Daily heating schedule
A daily schedule can be entered in the SmartThings device settings as:
00:00/17.0 06:30/21.0 09:00/18.0 12:00/20.0 17:00/21.5 22:00/17.0
This corresponds to:
Time Target temperature
00:00 17.0 °C
06:30 21.0 °C
09:00 18.0 °C
12:00 20.0 °C
17:00 21.5 °C
22:00 17.0 °C
Each new target temperature remains active until the next scheduled transition.
The required format is:
HH:MM/temperature HH:MM/temperature ...
The driver validates each schedule before transmission:
  • Exactly six transitions per day
  • Valid 24-hour time format
  • Transitions in strictly increasing chronological order
  • Target temperatures between 5 and 35 °C
Separate text fields are provided for Monday through Sunday under Device settings.
Important scheduling details
The schedule preferences are primarily used to write programs to the thermostat. They are not automatically synchronized displays of the schedules already stored in the device.
An empty schedule field means that no new program will be transmitted. It does not erase the existing schedule.
The driver validates outgoing schedules strictly. Incoming schedule reports are handled separately because Tuya firmware may report unused or unusual schedule slots that should not automatically be treated as valid user input.
To stop following a weekly program, simply select Heat instead of Auto. There is no need to erase the stored schedule or reset the thermostat.
Installation
The driver is available through my SmartThings Edge Driver channel:
Join my SmartThings Edge Driver Channel
  1. Open the invitation link and sign in with your Samsung account.
  2. Accept the invitation and enroll your SmartThings Hub.
  3. Under Available Drivers, install Tuya TS0601 Radiator Thermostats.
  4. Put the thermostat into Zigbee pairing mode.
  5. In SmartThings, select Add device and start a nearby-device scan.
The driver should be selected automatically when the thermostat reports one of the supported manufacturer fingerprints.
Pairing
For the original AVATTO ME168_1 variant, the pairing procedure is:
  1. Switch the thermostat to manual mode.
  2. Turn the temperature down until OF appears.
  3. Press and hold the rotary button until the network symbol starts flashing.
  4. Start Zigbee device discovery in SmartThings.
Other supported models may use slightly different pairing procedures.
If the thermostat is currently paired with another Zigbee gateway, remove it from that network first.
Existing SmartThings devices using this driver normally do not need to be removed and paired again when the driver is updated.
Technical details
Tuya proprietary Zigbee protocol
Although these devices use Zigbee, they do not expose their heating functions through the standard Zigbee Thermostat cluster (0x0201).
Instead, they communicate through Tuya’s proprietary datapoint protocol:
Zigbee profile: 0x0104 (Home Automation)
Tuya cluster:   0xEF00
Reference EP:   1
The driver implements the required Tuya command and datapoint encoding and decoding, including initialization, status reporting, time synchronization and schedule transmission.
Relevant datapoints
DP Data type Function SmartThings handling
2 Enum Operating mode Auto / Heat / Off
3 Enum Running state Heating / Idle
4 Value Heating setpoint × 10 Heating setpoint
5 Value Measured temperature × 10 Temperature measurement
7 Boolean Child lock Device preference
28–34 Raw Weekly schedules Seven daily schedule preferences
35 Value / fault Fault or low-battery indication Diagnostic handling
36 Boolean Frost protection Device preference
39 Boolean Valve anti-scaling Device preference
47 Signed value Temperature calibration Device preference
101 Value Heating demand / valve indication Diagnostic value
For example, a heating setpoint of 21.0 °C is transmitted as the integer value 210 through DP 4.
Weekly schedule encoding
Each daily schedule uses a 25-byte raw datapoint payload:
Byte 1:
  Weekday identifier (1–7)
Bytes 2–25:
  Six transitions, 4 bytes each
Each transition:
  Byte 1: Hour
  Byte 2: Minute
  Byte 3: Temperature high byte
  Byte 4: Temperature low byte
Temperatures are represented as big-endian unsigned integers in tenths of a degree Celsius.
For example, the transition 06:30/21.0 is encoded as:
Hour:           06
Minute:         1E
Temperature:    00 D2
Complete entry: 06 1E 00 D2
Here, 0x00D2 equals decimal 210, representing 21.0 °C.
The seven weekdays have separate datapoints:
Weekday DP
Monday 28
Tuesday 29
Wednesday 30
Thursday 31
Friday 32
Saturday 33
Sunday 34
The driver converts the readable schedule strings entered in SmartThings into these binary payloads.
Initialization and reporting
Some Tuya devices require an initialization read before they begin reporting their thermostat state.
The driver performs the appropriate Basic-cluster initialization and handles incoming Tuya datapoint messages through 0xEF00.
Temperature, setpoint, operating mode and running-state reports are translated into SmartThings capability events.
The implementation avoids unnecessary polling of the battery-powered thermostat.
Time synchronization
The thermostat maintains its own internal clock, which is used to execute its weekly schedules.
It can request time synchronization through Tuya command 0x24. This protocol family uses the January 1, 2000 epoch, rather than the Unix epoch of January 1, 1970.
The driver supplies the required UTC and local-time information.
The configured local-time offset must match the thermostat’s location. For example:
Timezone UTC offset
CET (winter) +60 minutes
CEST (summer) +120 minutes
Correct local time is important for the execution of the stored schedules, particularly across daylight-saving transitions.
Notes and limitations
  • The driver supports the listed exact manufacturer fingerprints, not every device identified as TS0601.
  • Weekly schedules are stored and executed locally by the thermostat.
  • SmartThings schedule preferences are write controls rather than synchronized schedule editors.
  • Empty schedule fields do not delete previously stored programs.
  • The reported heating-demand value does not provide independent manual valve-position control.
  • Fault/low-battery reporting is supported, but no reliable battery percentage is available.
  • Local-time configuration must be considered when using the weekly scheduler.
  • The thermostat’s internal protective functions remain device-controlled.
Testing and feedback
The original _TZE200_rxntag7i variant has been tested with SmartThings, including pairing, thermostat operation and device preferences.
The additional fingerprints extend support to other models using the same Tuya protocol family. Feedback from users with these devices is welcome, particularly regarding setpoint reporting, operating modes, protection settings, calibration and weekly scheduling.
If you encounter a problem, please include the exact Zigbee manufacturer string and model, a description of the behavior, and preferably SmartThings Edge driver logs.
Commercial model names alone are often insufficient to identify Tuya protocol differences.
References
Thanks to the Zigbee2MQTT, ZHA and deCONZ contributors for documenting the Tuya protocol, and to the community members who help test the driver with real devices.
This is a community-developed SmartThings Edge driver, not an official Samsung, SmartThings or Tuya release.
