anyone else still having issues?
Smartthings controller shows the server offline for me.
I am using the same IP and port as 1.0.4 when it was working. I have closed all docker containers and images and started with a fresh download. I have uninstalled the controller from smarthings and reinstalled. Still nothing. I am guessing it’s something dumb on my end but I have other edge devices running from this computer with different ports and they are running just fine.
Hm now you got me thinking…
The gateway hardware device did change. I updated my hardware, but I did a backup on the old device and restore on the new so all setting are the exact same as before. I just checked and the gateway IP is indeed the same as before.
I tried installing the MyQ connector BETA driver to see if that would do anything different. I realized that if I had both the regular and beta driver installed it would create 2 devices one for each.
I have since removed the beta driver and only have one device installed.
The IP @jkp mentioned should return with something if its missing credentials, error, etc. so I would start there on your troubleshooting. Until the page returns a status, there’s your issue.
If you have other components on that device (pi-hole, docker, etc.), do they return?
