have you tried removing the Edge driver and installing/setting it up to see what happens?
Iâm having the exact same issue. Anybody know specifically which steps resolve this problem?
Api error 429 for the last 8 hours. Is it just me? Seems like the myq server has blocked me, which has happened before but it always opens up after an hour or so.
what is your MyQ polling set to?
- Too frequent?
up it to see if you get unblocked⊠start with 30 or higher until you are working again. may take that hour you mentioned.
Started getting the API 429 error myself when my Windows PC updated and rebooted. Canât change anything to get it working again.
My polling was at 13⊠trying your suggestion and have moved the polling to 35 for now. I will give it some time.
had the same problem, but kept scrolling around the rooms and the garage door was added to where my SmartThings hub was.
works like a charm! thanks to the dev @brbeaird ! (installed it on my Synology via Docker. First time using Docker and I had to figure out to load the container with the âhostsâ option as the default does port mapping⊠but otherwise, it was fairly easy and simple.
did this cus I refuse to pay for MyQ Telsa subscription when I have SmartThings, Wyze cams and all this tech!
THANKS AGAIN
Still getting error 429 after increasing to 30 last night. Is anyone else seeing this?
have ypu upgraded your MyQ server to version 1.04 in the past month? sorry⊠I forgot to ask last night.
Ok. I have like 30 routines tied to the devices. Assuming that will require re-adding them or re-diting them back? Whatâs strange is that my login has not changed and it has been working for weeks.
hopefully @brbeaird can answer your questions.
I changed my IP just to see if that helped - now I am not receiving the credentials message. If I understand correctly this is just now showing as a plain block from the myq server?
Yes, this happen sometimes. I would try shutting it off for an hour or so and then trying again, maybe set your polling interval higher to like 30 seconds.
Thanks. - I did this last night and it was turned off for like 8 hours. I have had this happen before where it usually blocks for an hour or less, but this time has been for almost 12 hours now.
By changing my IP address shouldnât myq recognize me as a ânewâ user?
ALso with VPN on I receive the credentials message again. So Iâm alternating between two different 429 errors depending on if VPN is running.
Some Home Assistant users have been reporting error 429 since yesterday so not sure if it is related: https://github.com/home-assistant/core/issues/101763. I maybe pointing out a totally off-base issue.
Could be. Seems odd to me that other Smartthings users arnât seeing the same issue with so many of us using this integration though.
I am down. It was fine and just it went down.
