[ST Edge] Slide Curtain (local): Slide by Innovation in Motion curtain motors over the local API
A local Edge driver for Slide curtain motors. Runs entirely on your hub, talks to the Slide over your own network, no cloud.
Which Slide? The retrofit curtain motor “Slide” by Innovation in Motion (Amsterdam), the white box you clip onto an existing curtain rail, Wi-Fi only. The product was taken over by Smart Innovation Partners (slide.store) and is back in production. It is not the Zemismart/Tuya curtain track that is also called “slide”, not SwitchBot Curtain and not a Zigbee or Matter motor; those have their own drivers.
What you get, one device per Slide:
  • Open / close / pause
  • Position 0 to 100 % (100 = open), so it works in routines and with voice assistants as a window shade
  • Refresh, online/offline
  • Works with the current firmware (API v2, no password) and with old firmware (API v1, Digest auth with the device code on the Slide)
Before you start
  • Switch on the Local API on the Slide. Current firmware: in the Slide app. Old firmware: press reset twice, LED blinks 5x fast = local API on (2x slow = back to cloud; on old firmware the Slide app stops working while local is on).
  • Give each Slide a fixed IP in your router.
Install
  1. Channel invite: SmartThings. Add a little smartness to your things. (Stoeckie Edge Drivers), install Slide Curtain (local).
  2. App > Add device > Scan for nearby devices. The driver scans the hub’s subnet (POST /rpc/Slide.GetInfo) and creates a device per Slide, named Slide <last 4 of MAC> or the zone name from the Slide app. The IP is stored on the device and updated by a later scan if it changes.
  3. Only if a Slide is not found: device > Settings > fill in its IP.
Source and README: https://github.com/Stoeckie/smartthings-slide-local
Two things I ran into while building it, for other driver authors:
  • config.yaml needs discovery: {} next to lan: {}. Without it the hub never sends a scan to the driver and a driver without devices never even starts, so logcat stays empty. Permissions can not be changed on an existing driver id, so that means a new packageKey.
  • A v2 hub that is full silently refuses new installs with NotFoundError ... Failed to install Driver and stops picking up updates. smartthings edge:drivers:prune --hub <id> fixes it.
Tested with three Slides on a v2 hub. Feedback and logs welcome here or on GitHub.
That’s interesting, because edge:drivers:prune ignores LAN drivers:
Edit: looks like it only ignores default (pre-installed) LAN drivers.
Good catch, thanks. I had the same thought when I read the source. The filter only excludes the default LAN drivers that come preinstalled on the hub, so community LAN drivers that are not in use are pruned normally. On my v2 hub prune removed two unused drivers and after that the Slide driver installed right away.
