[ST Edge] Škoda cars via the official MyŠkoda API: battery, charging, cable, climate and doors (small bridge, Windows or Docker)
Škoda opened an official public API for MyŠkoda cars. This brings your Škoda into SmartThings with it, through the small Stoeckie Bridge (Windows or Docker) and its Edge driver.
What you get
  • Battery (state of charge) and charging power
  • Optional battery history graph: SmartThings draws no graph for battery %, so the setting Battery history graph can repeat it as a humidity reading (graph in %, the device then also counts as a humidity sensor) or as watts in an extra part Battery % (1 % = 1 W). Default off
  • Switch: start and stop charging
  • Charging cable: plugged in or not
  • Climate: air conditioning on and off at a temperature you choose
  • At home: the car is at its saved charging location
  • Doors open or closed
  • Routine examples: cable plugged in and battery below 30 % > start charging, weekday 7:15 > climate on, car not at home and a door open > notification
How it works
Edge drivers can not reach the internet. The bridge on a pc that is always on reads the car through the official API, the Edge driver on the hub reads the bridge over your LAN. The API allows 20 requests per hour per car, so the bridge reads the car every 10 minutes (adjustable in the device settings) and checks 30 s after a command.
Before you start
  • MyŠkoda app 8.16 or newer: Settings > Smart Home > API keys, create a key for your car
  • The VIN of the car (in the app and on the registration papers)
  • A pc that is always on with a fixed IP: Windows (installer included) or any Docker host
Install
  1. Install the bridge and the driver from GitHub - Stoeckie/smartthings-stoeckie-bridge: Stoeckie Bridge: cloud appliances (AEG/Electrolux, Fujitsu FGLair, Škoda, iRobot favorites) in SmartThings. Bridge for Windows or Docker plus Edge driver · GitHub (Windows: install.bat, Docker: docker compose up)
  2. Enter the API key and VIN in the Škoda section of the setup page (http://localhost:8787/setup)
  3. Enroll your hub: SmartThings. Add a little smartness to your things. (Stoeckie Edge Drivers) and install Stoeckie Bridge (local)
  4. Add device > Scan nearby. The car appears under the Stoeckie Bridge
Škoda page with details: GitHub - Stoeckie/smartthings-skoda-bridge: Škoda cars in SmartThings via the official MyŠkoda public API (uses the Stoeckie Bridge) · GitHub
Developer notes
Running here with a Kodiaq iV plug-in hybrid. Feedback welcome, especially from Enyaq and Elroq owners.
Tip: also a “back online” notification
If you made the Offline routine (Stoeckie Bridge (Škoda car) device, Connection is Offline, send notification), duplicate it in the app and change the condition to Connection is Connected, with a text like “Stoeckie Bridge (Škoda car) is back online”. Then you know the problem is over without opening the app. The device also shows Last drop (when, how long, why).
README updated with the same tip.
Update for the Škoda bridge (2026-11-06c)
All texts on the bridge setup page (where you enter the Škoda API key and VIN) are English now.
Running it in Docker? You no longer need a text browser in the container: just browse to http://localhost:8787/setup on the machine that runs Docker, also when you use port mapping instead of host networking. Want to use another pc for setup? Put its IP in STBRIDGE_SETUP_ALLOW (docker-compose.yml) and use https on port 8443. See README section 1b.
Updating: git pull and docker compose up -d --build, or on Windows copy the files and rerun install.bat. Your config is kept.
Škoda users: bridge 2026-11-06g needs Python 3.13
Running install.bat again upgrades the Windows bridge to Python 3.13 by itself; your MyŠkoda key in config.json is kept. Docker: rebuild (python:3.13-slim). The car device itself is unchanged. New in this version for others: Bosch, Siemens and Neff appliances locally, see [ST Edge] Home Connect (Bosch, Siemens, Neff) dishwasher and oven, local without cloud: status, door, temperature, stop (small bridge)
New bridge version 2026-11-07a, a maintenance release: Python 3.14 instead of 3.13 (Windows installers for 3.13 security fixes stopped in October). Update on Windows with install.bat, in Docker with git pull plus docker compose up -d --build. Your Škoda key and settings stay in config.json; the car devices keep working as before.
Update for Škoda cars: driver 2026-11-09d and bridge 2026-11-09d
Warning: the LAN API of the bridge is now closed until a SmartThings hub is paired. If your setup page already says “SmartThings hub paired”, nothing changes. If not: after updating, the devices stop updating until you open the setup page, press Pair, wait until your hub shows up with its IP address and press Allow (driver 2026-11-02b or newer).
  • Fixed: Only changed values go to the hub. Battery, range and charging values no longer get stuck in the app because the hub dropped events.
  • Bridge security fixes: the bridge only hands its token to the hub you allow, and an unpaired bridge no longer accepts commands (lock, climate) from the LAN.
All details: [ST Edge] Rain radar (Buienradar NL/BE, Open-Meteo worldwide): rain now, starts in, lasts, with radius (small bridge) - #14 by Stoeckie
Update: driver via the channel; bridge with git pull and docker compose up -d --build, or the new stoeckie_bridge.py and install.bat (Windows).
Driver 2026-11-09h: routines on the Škoda cars via the official MyŠkoda API devices no longer run again after a driver update or hub reboot (the first value after a start was sent as a forced event). Details in the bridge topic.
