I have developed my own Zwave windows roller shades (windows treatment), with a Z-uno module.
With the device handlers I could just connect my roller shade controller to the ST hub, and it was recognized as a thing. I then switched the device handler to Zwave windows shade device handler, and it work perfect.
A Zwave windows treatment in principal works like a multi switch (dimmer) where you can give a value from 0 to 100, and for a dimmer it means light from 0% to 100%. On a windows treatment it works kind of opposite, when shade are closed the value is 0%, and full open, it is 100%.
I have looked into the supported devices in the fingerprint file for SmartthingsEdgeDrivers Zwave windows shade, and my shade is of course not in the list.
How do I get SmartThings to chose correct edge driver?
Can I add the the manufactor id and model to fingerprint of Zwave windows treatment, so my roller shades will be recognized correct?
Or can I switch edge driver when Samsung converted my roller shades to a βthingβ, to the Zwave windows treatment?
I just looked in the fingerprint file for the Z-wave Window Treatment Mc, and it seems that the device you added, id: 0115/0110/0001, is not there anymore.
I installed the driver, but if it is not in newer drivers, then I guess I will not be possible to add the windows treatment later again?
I did not have luck excluding my windows treatments, to include them again with your edge driver, for any reason I am investigating, they will not excludeβ¦
I hoped that the automatic transition that Samsung should make until January 1st, from DH to ED would change the driver, but nothing happened so far.
Are Samsung delayed with the transition?
