[ST Edge] Philips Hue LAN [BETA] (3rd Party Driver, Not ST Native)
@blueyetisoftware i have 3 hue motion sensors, somehow they r not responding to the motions until i refresh it (by scrolling the device down). Not sure what is the issue, this happens only recently.
When i check the hue app, the motion sensors did shows motion detected. Any idea how to troubleshoot this ? Thanks
Itā€™s probably an app caching problem. I would try to reset the ST hub. After that I would try to restart your phone.
Newly back to ST and this looks amazing, and just what I need as have a lot of hue lighting in our home. Iā€™ve followed the first part of the instructionsā€¦enrolled and added the driverā€¦I can see the driver there but when I tap add device it just keeps saying no new devices foundā€¦am I missing a step?
Iā€™ve rebooted the hub, app, removed and re-enrolledā€¦any advice much appreciated
You donā€™t need to press the button. If you do, youā€™ll get the default ST version of the driver. The hub should show up without any presses. I would start by making sure that your Hue hub is on the same network as your ST hub. Youā€™d be surprised how often this is missed. People like to quarantine systems using VLANs and sometimes they canā€™t see each other.
@blueyetisoftware - Thanks so much for the response. Feeling a little silly now as that was totally the case. Changed ISPā€™s just this week and thought Iā€™d moved everything over, turns out hue was still plugged into the old router, doh!
Now added, although getting the message ā€œThis device hasnā€™t updated all of itā€™s status information yet. Check again laterā€
I am presuming I just need to be patientā€¦or is this something else Iā€™ve missed :confused:
EDIT: I noticed someone having the same issue above, I have rebooted both the Smarthings and Hue hubs and still getting same error message :cry:
FURTHER EDIT: I have removed the device, driver, un-enrolled then rebooted. Then re-enrolled and re-added the driver and rebooted again. And although it still showed the same message it allowed me to link. Seems to be working :crossed_fingers:
I do have the same problem. After a reboot of the ST hub.
This is working well!
But there is something strange with wall switch modules.
When I have 2 switches it displays 3 buttons.
Also is there a way to implement actions when pressed several times ?
Thereā€™s actually actions for basic and push switches
One button control both relays together and the other 2 switches control the individual relays separately.
Not directly unless the driver emulates it. And the emulation may or may not work depending on the debouncing of the button.
I made a Edge driver that among other things can run multiple actions with just one button: [Edge] Virtual Scene Switcher, more than a fun way to cycle through scenes - #28 by mocelet
If multiple presses are registered correctly by the button youā€™ll be able to execute multiple actions.
Iā€™m not really following this, but the driver exposes the events that are exposed by the Hue hub. If it support multiple presses in its API, the driver will have that. There is no emulation. The driver adheres to the standards of the device.
Does this driver work with the v1 Hue Bridge? Iā€™ve only got a couple of older Hue bulbs (since invested in other brands), so I donā€™t want to buy a new bridge just for them. When I try to scan nearby devices, the Hue bridge doesnā€™t show up (regardless of whether I press the physical button on the Hue bridge or not).
No. It only works with the V2 hub which supports the newer API.
@blueyetisoftware - When I go into a device to change itā€™s color, whatever color I select on the spectrum, as soon as I lift my finger, it jumps to another nearby random color. Only happens with this driver.
You are not alone.
It seems like the resolution of colors is 8bits rather than something like 16bits or 65536 colours and it ā€˜catchesā€™ the closest.
The red is never pure for the same reason?
slightly washed out, a bit orange/pink.
But I love :heart: :heart_eyes: this driver otherwise!
Hi @blueyetisoftware , i been consistently having this issue recently, but could just refresh the linking of the hub when the hue devices did not function per the status when triggered or on/off. However last 2 days although the hub still shows it is connected, the devices connected are not able on load its status etc on/off. I tried relink but it just show the below
I tried rebooting the smartthings hub, router and hue bridge and still the same.
I login to the smartthings ide and try the linking via the login and it shows the command is sent, but does not allow me to relink tooā€¦
Could you advise how do i troubleshoot this?
Hello. Thanks for the awesome edge driver development.
I have connected a Hue Dimmer Switch to my ST Hub without going through the Hue Bridge.
I want to use the Hue Dimmer Switch connected to the ST to change the brightness of the lights connected to the ST through the Hue Lan Edge Driver by a certain level.
I looked it up and found that the Hue v2 API has a function called bri_inc.
Is it possible to add this function to your Edge Driver?
Hi @blueyetisoftware can assist to advise? Thanks
Is the Hub firmware on the 54.5 beta version?
Yes, it is beta ver 54.5.
I have another LAN device also having same error
Both devices including this philips hue lan devices are currently having this error after the software was roll out on 27Aug. The last event on these 2 devices are on 27Aug per below and then the errors appear
@Luis_Humberto_Medina , do assist on this issueā€¦
@blueyetisoftware
also, it would be great to be able to adjust the color temperature or set color Rooms as well.
