[ST Edge] Personal Tuya Devices - Generic EF00 Device
Give some more information regarding your device.
Thanks for the reply, its a solar temp and humidity soil sensor.
after some googleing and guessing i think the humidty is on DP3 and the temp is on DP5, however i cant get a status update on the battery and keeps telling me its at 2%. i have pasted the link below. let me know if you require anymore info,
thanks for helping
https://www.aliexpress.com/item/1005009073856156.html?spm=a2g0o.order_list.order_list_main.11.48321802yVwrM0
just a bit of a update, i don’t think the humidity is working either it sat at 30% for weeks
When you see 30% might be received problem. If you like you can send here some CLI logs of your device so the DP can be verified.
Here are some instructions regarding how to create:
thanks for the assist,
i have used the the instructions and connected to the device, how ever nothing happens after than
never mind after some clicking around i managed to get the following info
Hi,
Thank you for this. I have added a temp and humidity but i cant test its accuracy because its so random in the updates. Its been over ten minutes and it didnt update even though i am holding it to see if it will go higher, should be closer to 30…
Is there a way to incrase frequency?
I am not sure if i see the data points… see below…
When a new message will received from your device it will be displayed in SmartThings app. You received messages every 5 minutes , looks fine for me.
DP’s are property define since you are getting the temperature and the humidity.
Hi
Not really. Not sure why it showed 5 minutes once but i left it overnight and humidity seems every 30 mins but temp was all over the map. Sometimes minutes ans some times hours…
Is that normal?
The ST App history doesn’t show what the device is sending. The history shows the value when it changes. ST filters even more temperature values.
The only way to know what and when the device is sending is to use the CLI smartthings edge:drivers:logcat command.
ohh, I didn’t know that.. so if I put it in the fridge I should see a new temp :slight_smile:
maybe it’s not that sensitive then because on other tuan ones which are not EF00 I can see them much more frequntly. Thanks for the note. I’ll try to check logcat as well.
Hi @w35l3y , Hope you can help me.
I have a Zemismart 6 gang light siwtch model TS0003 by manufacturer _TZ3000_uilitwsy, and when I try to use your “Default Clusters” it Doesn´t create any of the child switches.
It recognizes your “Default Drivers”, also “Personal Tuya Devices - main”, in the case of this last driver, it creates the 6 switches but they don´t work.
Are you able to add this model and manufacturer to the Edge Driver, and recognize the 6 gangs?
DO you need any other information ?
I solved the problem, this 4x4 6 gang is in reality two separate devices.
if you press the left top switch till it starts blinking it will add a 3 switch device.
Then you have to press the right top switch till it blinks then it will add another 3 switch device.
With this you will have 2 devices with each one with 3 switches and it will work this way.
Hope this helps any other person that buys this 6 gang Zemismart TS0003 switch light.
Great caching… There is a small clue. The device is TS0003 which referring to 3 switch gangs.
If it was TS0006 than it will be refer and 6 gangs switch.
And one more thing… it is always a good practice to read the manual (RTFM… :grinning_face:)
Just reporting in success on getting a Soil moisture / Temp Sensor to work.
dont ask why only this ‘‘Manufacturer’’ worked when there are those who use
the datapoints i had to change to..
Not sure the DP for Battery is working. Time will tell.
Hi, could you please add the window opener for device in screenshot?
Hi,
This can be done by selecting profile Window Shade in settings instead of the Generic profile that you currently use. The following DP (Data Points) are in use:
Only State and Position are relevant.
I recommend also using Tuya Hub for setting the other parameters.
Hi, @dotan_shai thanks for your help, but when I changed the profile to window shade the level, open and close button does not work, do you know how can I proceed?
If you press the 3 dots, you can see settings. Select it . You will be able to enter DP for:
Window shade set to 102
Window Shade Level set to 104
all the rest DP , if needed , can be set by temporary connecting to Tuya hub , setting and reconnecting to ST hub.
How can i get values from default clusters, like battery and water leak (cluster 0x0500) and datapoints from the EF cluster like voltage sensor value for the same device?
