Is there a way for a user to opt-in or opt-out of auto upgrades of a driver once they are enrolled in a channel? Is being enrolled considered opting in? I have had a couple requests from users wanting to manually update drivers.
Hi, @blueyetisoftware.
I’m checking this with the engineering team. I’ll come back once I have more information
Nayely there was an initial business requirement to be able to manage the channel subscriptions, invite and remove hubs/accounts. The invite part is implemented when can we expect the manage/remove part ?
Following up on this question, the team mentioned there are no current plans to allow a manual update of the driver. However, they are aware of this requirement, in case something is defined, they will let us know.
I’m asking around about this, so far there’s no updated info regarding the feature of “channel enrollment management”.
Update:
@RBoy, there’s no information about the feature you requested yet. In case we have an update, we’ll contact you directly.
Thanks. I have some users on an alpha testing channel. They only way they know something has changed is if I send them a note. They can’t decide when to update, nor are they notified when a new driver is installed on their hub.
