I have tried the Beta Driver stock Z-wave Button with a Fibaro KeyFob and it works, but the detail view is very very bad.
The KeyFob has:
6 Buttons and each Button has actions:
- Pressed
- Pressed 2 times
- Pressed 3 times
- Held Pressed
- Pressed down
- Battery
What it shows in the details view:
- Shows the messy buttons and there are 6 buttons + a main button, which matches in actions with button 1.
Each button shows:
- Pressed 1 to 6 times and only works until pressed 3 times.
- Pressed up 1 to 6 times
- Pressed down 1 to 6 times
- Missing Held Pressed on each button
- The battery information comes after the Main button instead of at the end.
- The order of the buttons is shown in details, and Routines: Button 1, Main, Battery, 6, 2, 3, 4, 5
A screenshot with a part of the detaills view:
Log configuration seems correct
2021-11-13T11:24:19.547051600+00:00 TRACE Z-Wave Button Setup driver zwave_button with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_button
default_handlers:
added:
driverSwitched:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
default_handlers:
doConfigure:
child_dispatchers:
2021-11-13T11:24:19.555321600+00:00 TRACE Z-Wave Button Setup driver zwave_button with Capability handlers:
CapabilityCommandDispatcher: zwave_button
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
default_handlers:
child_dispatchers:
2021-11-13T11:24:19.567377266+00:00 TRACE Z-Wave Button Setup driver zwave_button with Z-Wave handlers:
ZwaveDispatcher: zwave_button
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
ZwaveDispatcher: zwave_button -> Z-Wave multi button
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
default_handlers:
BASIC:
SET
child_dispatchers:
2021-11-13T11:24:19.621423267+00:00 TRACE Z-Wave Button Received event with handler _resync
2021-11-13T11:24:19.627290600+00:00 TRACE Z-Wave Button Received event with handler environment_info
2021-11-13T11:24:19.642383933+00:00 TRACE Z-Wave Button Found DeviceLifecycleDispatcher handler in zwave_button -> Z-Wave multi button
2021-11-13T11:24:19.648202267+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:19.654399600+00:00 TRACE Z-Wave Button Received event with handler environment_info
2021-11-13T11:24:19.659613933+00:00 DEBUG Z-Wave Button Z-Wave hub node ID environment changed.
2021-11-13T11:24:19.672999933+00:00 TRACE Z-Wave Button Received event with handler device_lifecycle
2021-11-13T11:24:19.679284267+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received lifecycle event: added
2021-11-13T11:24:19.687471933+00:00 TRACE Z-Wave Button Found DeviceLifecycleDispatcher handler in zwave_button
2021-11-13T11:24:19.694073933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> emitting event: {"state":{"value":6},"component_id":"main","attribute_id":"numberOfButtons","capability_id":"button"}
2021-11-13T11:24:19.742959267+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> emitting event: {"state":{"value":["pushed","held","double","down_hold","pushed_3x"]},"component_id":"main","attribute_id":"supportedButtonValues","capability_id":"button"}
2021-11-13T11:24:19.761213933+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:19.768617933+00:00 TRACE Z-Wave Button Received event with handler device_lifecycle
2021-11-13T11:24:19.774870600+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received lifecycle event: doConfigure
2021-11-13T11:24:19.793774933+00:00 TRACE Z-Wave Button Found DeviceLifecycleDispatcher handler in zwave_button -> Z-Wave multi button -> Fibaro keyfob
2021-11-13T11:24:19.803031600+00:00 TRACE Z-Wave Button Found CapabilityCommandDispatcher handler in zwave_button
2021-11-13T11:24:19.810547933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={}, cmd_class="BATTERY", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2021-11-13T11:24:19.820832267+00:00 TRACE Z-Wave Button Z-Wave command(c8a5bad1) queued for radio transmission: CC:Battery, CID:0x02
2021-11-13T11:24:19.828575933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=21, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x15\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.839432267+00:00 TRACE Z-Wave Button Z-Wave command(0b5028fa) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.847973600+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=22, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x16\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.860413933+00:00 TRACE Z-Wave Button Z-Wave command(016b988c) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.869153933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=23, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x17\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.878068267+00:00 TRACE Z-Wave Button Z-Wave command(4f84ffab) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.886409600+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=24, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x18\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.896708933+00:00 TRACE Z-Wave Button Z-Wave command(1b6f7e46) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.905151933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=25, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x19\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.913924600+00:00 TRACE Z-Wave Button Z-Wave command(00bacaa8) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.922748267+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> sending Z-Wave command: {args={configuration_value=15, default=false, parameter_number=26, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x1A\x01\x0F", src_channel=0, version=1}
2021-11-13T11:24:19.932530933+00:00 TRACE Z-Wave Button Z-Wave command(c196d9b8) queued for radio transmission: CC:Configuration, CID:0x04
2021-11-13T11:24:19.937872600+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:19.977910267+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:20.026990933+00:00 TRACE Z-Wave Button Z-Wave command(c8a5bad1) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:20.157271267+00:00 TRACE Z-Wave Button Received event with handler unnamed
2021-11-13T11:24:20.174011933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received Z-Wave command: {args={battery_level=100}, cmd_class="BATTERY", cmd_id="REPORT", dst_channels={}, encap="S0", payload="d", src_channel=0, version=1}
2021-11-13T11:24:20.209298600+00:00 TRACE Z-Wave Button Found ZwaveDispatcher handler in zwave_button
2021-11-13T11:24:20.216679933+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> emitting event: {"state":{"value":100},"component_id":"main","attribute_id":"battery","capability_id":"battery"}
2021-11-13T11:24:20.244251267+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:20.300818267+00:00 TRACE Z-Wave Button Received event with handler device_lifecycle
2021-11-13T11:24:20.314769600+00:00 TRACE Z-Wave Button Z-Wave command(0b5028fa) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:20.337409600+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received lifecycle event: infoChanged
2021-11-13T11:24:20.356433934+00:00 TRACE Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received unhandled lifecycle event: infoChanged
2021-11-13T11:24:20.362864600+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
2021-11-13T11:24:20.447363600+00:00 TRACE Z-Wave Button Z-Wave command(016b988c) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:20.596414267+00:00 TRACE Z-Wave Button Z-Wave command(4f84ffab) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:20.786893934+00:00 TRACE Z-Wave Button Z-Wave command(1b6f7e46) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:21.006488934+00:00 TRACE Z-Wave Button Z-Wave command(00bacaa8) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:24:21.216456934+00:00 TRACE Z-Wave Button Z-Wave command(c196d9b8) transmit status: TRANSMIT_COMPLETE_OK
2021-11-13T11:25:18.653887172+00:00 TRACE Z-Wave Button Received event with handler device_lifecycle
2021-11-13T11:25:18.688361505+00:00 INFO Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received lifecycle event: infoChanged
2021-11-13T11:25:18.697798505+00:00 TRACE Z-Wave Button <ZwaveDevice: 7a61f49e-d9c2-47d3-8fe1-fd02b9147cb1 [0F] (Fibaro KeyFob)> received unhandled lifecycle event: infoChanged
2021-11-13T11:25:18.703317839+00:00 DEBUG Z-Wave Button Fibaro KeyFob device thread event handled
