Unfortunately the ST platform doesn’t support dimmers, there were option in ST SmartLights App but it doesn’t work with Edge devices .
But there are still two options:
use cloud Groovy app, there are plenty “Sync Dimming” apps around, I can publish my version which is stripped version of someone s code.
It works with a significant delay but you can have a dimming proportional to the cube rotation
use Edge driver “Zigbee Light Multifunction MC”. There is a capability to increase dimming by constant value
For those interested in the mirror functionality, I shared in this post two examples using the Rules API, one for the Switch capability and the other for those capabilities that use commands with arguments to set the attribute’s value (in this case, switchLevel).
@nayelyz Or if we can join that Rule Builder tool, even if it is in Beta stage. Anyway Edge is in Beta too.
I am pretty sure any user input is good input.
I have 3 Routines in the app. Two of those are only because Notifications weren’t documented for the Rules API last time I checked and they are beyond my limited reverse engineering abilities (my abilities being limited to making guesses). The remaining one is to change a Location mode at a certain time and is only there because I need to enable and disable it easily.
I have 3 Scenes in the app. This bothers me. If Scenes could be created independently from the app I’d move them all immediately. Alternatively if there was a Rule to execute another Rule directly I’d be using that.
I only have in the region of 80 to 90 Rules as my needs are simple. It worries me that there is said to be a limit of 100 Rules. The minimum needs to be at least 500.
I’m afraid in this context you don’t count @orangebucket, you even have “Developer” in your tag. A “user” would be any regular user, that has only one hub, is not a developer, does not create device type handers, has an I.Q. less than 170, of which precisely zero are using the Rules API @nayelyz
Here are two demo tools that can help you understand how to build a Rule and create/delete it.
Crafting a Rule. This tool helps you build Rules using:
Time references to turn on/off a Switch
Turn on/off a device based on the temperature of another (above, below)
Turn on/off a device when presence is detected
Turn on/off a device when the location mode changes
Lock/unlock a device when an event lasts for x amount of minutes
Note: Please, avoid submitting a Rule from this tool unless you save its ID, this is because it won’t be listed on the other tool or in the request to the API (Rules endpoint) using a Personal Access Token (PAT).
Listing, creating, and deleting Rules. This other tool helps you execute these actions on the selected location.
To create the Rule, you must paste a valid Rule in the Submit Rule tab and click on “Submit”. It can be one from the samples or one crafted in the other tool. Note: you can check how to change the commands/conditions to adapt it for other capabilities, also, you can get creative and combine them to form a more complex Rule.
To delete a Rule, you can list the existing ones in the “List Rules” tab, get its ID and use it on the “Delete Rule” tab
Note: Remember that all the Rules created here won’t be retrieved using a PAT, also, the ones created with this type of token won’t appear in the tool.
We also welcome anyone who is interested in building and maintaining an independent app on top of the API, we love seeing the Community members’ great ideas and skills and of course, I’ll be glad to help in case questions come up.
Have these tools been updated? I checked this out a couple of years ago. I created a test rule in which a Xiaomi temp sensor turned on a ceiling fan at 72F. It worked but I don’t remember why Ii stopped using it. I remember I did have trouble deleting the rule, and had to delete the trigger to delete the rule.
@veonua
Can you add more functions to the cube. for now, for me only face and dimmer are working. I wish Tap, Toss , rotate and more will be available. Also RSSI and LQI
Also for everyone that wants the dimmer. I manage to mirror my cube dimmer to my office dimmer with Sharptools Rule Engine by using variables works for me (I think that using variables are not free @joshua_lyon) . Here is what I did:
Although tap and toss available in automations , in practice when tapping on the cube nothing happen. Also nothing appear in Cube controls. I can see only FACE. Dimmer, Motion Sensor (don’t know what means), Temperature Alert and Battery.
LQI and RSSI both are parameters that represent the signal reception at the device could you please add.
In my experience, the pressure sensitivity is very low, if you press your finger on the cube, it will not trigger an action. You must grab the cube and knock on a hard surface, usually twice
Motion capability, the cube sends the signal as it wakes , and its very sensitive.
So you can use the cube as the vibration sensor.
I use this feature for alarms
The temperature alarm will go away eventually, as im cleaning and aligning the view across devices .
I use one of these. All the functions work as intended, however, it is a bit sensitive. The DTH by DroidSector exposed the debounce time, which could be changed for user sensitivity. I believe the default time for debounce was 3600ms. Maybe this helps.
debouncing: Bouncing is the tendency of any two metal contacts in an electronic device to generate multiple signals as the contacts close or open; debouncing is any kind of hardware device or software that ensures that only a single signal will be acted upon for a single opening or closing of a contact.
I’ve noticed with my cube that a very small movement can activate the cube function, but a larger movement doesn’t do anything. I suspect it is the “bounce” in the switch. Changing the debounce time allows for broader movement, or less sensitivity to accidental movement.
I am just an end user and not a coder so I don’t know how to implement the code. My understanding is it’s used a lot in Arduino.
