Edge driver for iRobot Roomba robot vacuums. The hub talks to the robot over its own local MQTT connection (TLS): no cloud, no bridge computer, no IFTTT.
What you get
Robot cleaner movement: cleaning, pause, homing, charging, idle and alarm (stuck or error). Set it to start, pause, stop or send the robot home
Switch: on starts (or resumes a paused job), off sends the robot back to the dock
Battery level
Empty bin button for robots with a Clean Base
Favorites list: your iRobot app favorites (room cleaning) plus Whole home and Idle. Names come automatically with the optional Stoeckie Bridge, see the update below
Live updates, the robot pushes every change
Routine examples: movement changes to charging > “Roomba is done”, movement is alarm > “Roomba is stuck”
Which robots
Roombas with wifi that run the local broker: 600 and 900 series with wifi, i3, i7, i8, s9, j7 and similar. Tested with a Roomba s9+ (firmware 22.29.10).
The 2025 models (105, 205, 405, 505 and others) refuse local connections. The Combo 10 Max, Plus 500 Combo and Max 700 have Matter instead, pair those as a Matter device.
Add device > Scan nearby. Your robot appears with its iRobot name
Put the robot on its dock and hold HOME for 2 seconds until it plays tones. The hub fetches the robot password and stores it. It keeps trying, so there is no hurry
The device goes online and shows the state
Give the robot a fixed IP (DHCP reservation). Not found? Set the IP in the device settings.
The robot accepts one local connection at a time. Disconnect Home Assistant or other local tools first. The iRobot app keeps working, it uses the cloud.
The password is stored on the hub only and never logged.
Off while cleaning sends pause first, then dock, like the iRobot app.
Protocol details from roombapy and dorita980. MQTT client and password request are written in Lua for the hub.
Running here with a Roomba s9+ and Clean Base. Feedback welcome, especially from other models.
I have a old Roomba 600 series out at camp. I installed your driver and it quickly found my vac. I am not currently at camp, so I can’t hold the Home button. I will do that next week when I am at camp. I will report back at that time with how it works.
I have my J9+ connected to HA using Hacs Roomba v4 which I will keep.
In case anyone is in the same situation;
I was able to share ‘Albert’ to SmartThings using the following which allows sharing of non matter devices in HA with matter.
Update: favorites are in the channel (your hub picks it up by itself).
New Favorites list on the device: Idle, Whole home and your iRobot app favorites. Pick one to start it, so only those rooms get cleaned.
Names automatically: the iRobot app keeps favorites in the cloud, the robot does not know them. If you run the small Stoeckie Bridge (Windows or Docker, see the AEG and FGLair posts), enter your iRobot login on its setup page. The bridge reads only the favorites twice a day, the hub finds the bridge by itself and shows them with their names. Control stays local. The login is unofficial (library roombapy-prime) and iRobot limits logins per account, so it is optional.
Without the bridge: start each favorite once in the iRobot app, the driver learns it, and you give the names in the device settings.
Rooms and favorites need a robot with Smart Maps (i, s and j series). A 600 series has no maps, so there you get start, pause, dock and status.
@Andrew_Bartlett thanks, good tip for Home Assistant users. The Matter Hub route keeps HA as the only local connection to the robot.
@Paul_Oliver on a 600 series hold the Home button (the dock button) for about 2 seconds while it sits on the dock, until it plays tones. Curious how it goes.
SmartThings has no routine trigger for “device offline”. The Roomba device now has a Connection status (Connected or Offline), so you can make a routine:
If Roomba > Connection is Offline, then send a notification to members.
Short drops (a reconnect or one missed poll) are ignored: Connection only turns Offline after 2 minutes without a connection. Every drop is remembered: when the connection is back the device shows Last drop with the time (UTC), how long it lasted and the reason.
For a device that drops off now and then (like a robot on a weak wifi spot) set “How long does this status last” to a few minutes. The driver updates itself from the channel; the status shows after the next poll. README updated.
The robot uses a self signed certificate, so the driver could not tell it apart from another device on the same address, and it would have sent the password to it. The driver now remembers the robot’s certificate at the first connection and refuses (without sending the password) when another certificate answers. Replaced the robot? Enter the password again and the new certificate is trusted. The driver updates itself from the channel.
I had a chance to finish setting up my Roomba Series 600 today.
I now have basic on/off controls in ST. It also shows the status (cleaning, charging, standby, paused, etc), and battery levels. It didn’t import favorites but they are very limited and only include cleaning times. These can be easily duplicated using ST routines, so it is no loss. I am not using a bridge.
So for a vacuum with very few features your integration has captured what is needed.
If you made the Offline routine (Roomba device, Connection is Offline, send notification), duplicate it in the app and change the condition to Connection is Connected, with a text like “Roomba is back online”. Then you know the problem is over without opening the app. The device also shows Last drop (when, how long, why).
Update build 2026-11-08a: favorites and Empty bin on the main card
The small Favorites and Empty bin tiles at the bottom of the device page (with generic button labels) are gone. Everything is now in one card on the main page:
Favorite: a list with Idle, Whole home and your iRobot favorites. Pick one to start it. The list shows what is running now.
Empty bin: a button in the same card (models with a Clean Base).
Both work in routines too: condition “Favorite is …” and action “Start favorite”.
This uses a new custom capability, silvervalley08660.robotFavorites. The driver updates itself through the channel; the device page may need a pull down refresh once.
Note: routines that used the old Favorites or Empty bin component must be set up again with the new Favorite card.
Update build 2026-11-08d: Connection card at the bottom
Connection status and Last drop are now in their own Connection card at the bottom of the device page. In the main card the app always put them above the cleaner controls, whatever the order in the profile.
Last drop starts with “No drops yet”, so the app no longer says “not all status information updated yet”.
Note: an existing Offline or Online routine must pick the condition again from the new Connection card (Roomba device, Connection, Connection status).
Update build 2026-11-08e: Empty bin with its state
Empty bin is no longer a small button inside the Favorite card. It has its own row with the bin state (Ready, Full or Emptying) and a switch that empties the bin into the Clean Base.
“Bin is Full” also works as a routine condition, for example to get a message when the bin needs attention.
New custom capability: silvervalley08660.robotBin. Pull down the device page once after the update.
Update build 2026-11-08f: no Offline notification for a short network outage
New setting Offline after (minutes), default 5. Connection only turns Offline after that many minutes without contact. Before it was 2 minutes, so a router or network update at night (a few minutes without network) gave an Offline notification even though nothing was wrong. A real outage still gives one.
Update build 2026-11-08g: no dock or restart when you only look at a list
When you open the Favorite list or the movement list and go back without choosing, the app sends the shown value again. That could dock the robot or start a favorite again. The driver now ignores a value that is already shown.
