[ST Edge] incorrect printing of Attribute ReportingConfiguration
minimum_reporting_interval is printed twice for AttributeReportingConfiguration
<ZigbeeDevice: 9941bd3d-8485-48b7-bc71-dc29a641084f [0xCBBA] (Girier relay)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCBBA, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, minimum_reporting_interval: 0x000A > > > >
It seems that maximum_reporting_interval has incorrect name when created
function AttributeReportingConfiguration.init(orig, data_table)
out.minimum_reporting_interval = data_types.validate_or_build_type(data_table.minimum_reporting_interval, data_types.Uint16, “minimum_reporting_interval”)
out.maximum_reporting_interval = data_types.validate_or_build_type(data_table.maximum_reporting_interval, data_types.Uint16, “minimum_reporting_interval”)
Thank you for bringing this to our attention.
I’ll mention this to the engineering team and let you know their feedback.
Update:
This issue was already reported, but it will be fixed in a future firmware release.
In Beta firmware 40.0006 is already fixed
2021-11-09T11:42:32.952759633+00:00 INFO Zigbee Switch Test  <ZigbeeDevice: b183b490-473a-4849-88f8-e77f92bcf1b1 [0x463C] (Extensor de Red)> sending Zigbee message: < ZigbeeMessageTx
|| Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x463C, dest_endpoint: 0x0B, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader
|| frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
