[ST Edge] DSC Security System / Envisalink Driver (2021)
Hi @TAustin I’m running into the same problem as @Delgreco007 when I tried to update from the beta to the latest 2.1 driver. I followed the instructions and deleted the old beta driver and all the devices. I’ve confirmed via CLI that there are no Edge driver installed.
Using CLI, I then loaded the latest Edge driver, which CLI confirmed was installed. When I go into the Mobile app to scan/discover the new panel, it finds a DSC Primary Panel. I then exit out the device discovery/scan page. But when I go to the unassigned room and tried to click on the new DSC Primary Panel, it says “Can’t connect to device. Check device and try again.” When I hold the panel down and click “Edit”, it doesn’t seem to give me any way to configure the device (no three dots at the top right corner).
