Thanks for the reply @TAustin!
I have defined all the zones, 1 extra partition, code, ip:port, password. I can see the primary panel connecting and am able to arm/disarm the panel from ST.
I am using ST Hub v3 (2018), Envisalink 4, turned off alarmserver integration (LXXero).
FYI, I deleted the v2.1 driver and installed your beta v2.0 driver and all the zones I added (as a test) showed up in ST.
I will follow the tutorial on cli from the link you sent me and am willing to help troubleshoot with logs if thta will help narrowing down the issue. I will not delete the beta driver until I hear back from you with further instruction/suggestions/recommendations to troubleshoot.
Thanks!
Edit2: i logged in to IDE and noticed the webapp “DSC Integration” app was still there. Also noticed that all my (new zones created with Beta driver) zones are still “cloud”. I thought I deleted all instanced of this integration, but will now delete this app in IDE and try to install the new driver. KYP.
