This driver is for zwave devices.
You were absolutely right, I had the device somehow installed with a DTH and Edge driver.
Great driver, thank you.
SmartThings have converted many of my Z-Wave switches and dimmers to the stock driver. I tried moving a few to your driver and all is good.
One frustrating thing, and nothing to do with this driver ⊠it seems the ability to update the LED indicator setting is not exposed via the API for Edge devices. I have rules in SharpTools that handled this on devices using DTHs but the capability doesnât show up for those using Edge drivers.
Is this something you change frequently? Most devices, including the four different GE/Jasco models I have, provide a tap pattern that will cycle thru the possible LED settings.
Nightly on a few devices in my master bedroom. During daylight hours I have the LEDs act as normal (in my case the default on when device is off) but at night I want them off.
I used to use an old Groovy rboy app to do it. More recently I was handling it via SharpTools as it was possible if your device is using a DTH. But it seems the API does not expose the capability for drivers. Itâs not available in native Routines either.
Even if I wanted to mess with them manually every night these are older devices without the option you describe.
Just another, albeit minor, step backwards.
Interesting.
I have about 90% of my devicesâ LEDs set to on-when-on. Master bedroom, also the great room (living, dining, kitchen) where there are so many smart switches you could almost read a book by their lights at night.
I think Iâd be confused by constantly flipping their state. But, as the saying goes, to each their own.
Hi @philh30 Iâm experiencing some delays in responsiveness to button presses. I went to try your recommendation to remove âTurn Onâ and just set a dimming level - it doesnât seem that this is separated, maybe this is deprecated?
@philh30 Any chance youâre going to add parameters (default dim level) for routines to the non-motion dimmers?
thank you for this!
Works well but I am noticing that sometimes itâs not registering which way the paddle switch is being double pressed and instead reporting âPressed 2 timesâ:
No real reason that I can tell and its for both the up direction and down direction. It happens when left alone and used for the first time as well as when testing it out for several minutes at a time.
Iâve seen the requests - both yours and the ones for the indicator light - but Iâm not in a position where I can commit to getting that done. I have limited time to work on ST integrations, and multiple projects competing for that time. I donât like to commit to something that I canât get to in a reasonable amount of time.
There should be two events posted for each button press - a generic âpressedâ and a more specific toggle with direction. Your event history is showing both. If youâre watching detail view then you may only see one pop up but both should trigger routines. At the time that I wrote the driver, I thought having both might be helpful but in hindsight the generic âpressedâ are probably unnecessary.
Perfect thank you!
Iâd need a bit more detail to really respond to this - for example, what youâre pressing (a button in the app or the physical device). Troubleshooting this sort of thing would require you to get live logging running in the CLI so that you can track where the lag is occurring. When Iâve looked into these in the past Iâve seen significant lag in the z-wave queue, which is outside the control of this driver. Another area of concern is if your hub is out of memory.
I think that recommendation was for when the âonâ command was setting dimmers to full brightness, but thatâs been fixed.
I have a new Enbrighten switch. If I try to select @philh30 's GE driver, it doesnât appear as an option? is there a way to force that driver?
This is the switch ID info:
I think Iâve figured out something. Basically I had Routines that were set to change the dim level of the lights (a GE 46204 toggle dimmer) â toggle up 2x=100%, down 2x=25%. Essentially the Routine would run reliably when the light was off, however when it was on, it would work maybe 10% of the time. The Button state would register the Toggle Up Twice, Toggle Down Twice, even tho the routine didnât run.
SO ⊠I added another condition to the same device âIf ON or OFFâ in addition to the 2x toggle, and now it runs reliably! Huh?
EDIT: Nope.
Well⊠itâs not fixed.
The strangeness I was experiencing was in fact due to the presence of the Turn On with Dimmer setting in the routine (all I was fussing with was just randomness). By removing Turn On (which I couldnât find initially â you have to âun-checkâ a radio button â I mean, really weâre inventing UI standards @smartthings? un-check a radio button???) the routine started working reliably and the light would dim accordingly (100% 29% 44% all started working if the light was already on).
Maybe itâs a new incarnation of the bug youâre referencing.
@philh30 Thank you so much for the hard work on making this work! I have a lot of legacy GE switches and dimmers around the house that are working great with this edge driver, but then I have some GE 45605 Z-Wave Duplex Receptacle, and cannot making work correctly.
After adding them with your driver, the system cannot recognize the device status. Even you can turn them on/off, they show offline.
Couldnât find any mention in all this thread about this specific model.
Any ideas will help. Thanks
@philh30 Any idea why this switch wonât allow me to select your driver?
ProductType: 0x4944
ProductID: 0x3431
ManufID: 0x0063
Jasco
thanks! grrat jobâŠSo, Its possible you can add the option to select icon for âwaterâ or âirrigationâ as below?
I am using your controller for a water pressurizer control
ST-Edge-Drivers/GE-Jasco at main · philh30/ST-Edge-Drivers · GitHub
Those are the fingerprints that are recognized by his driver. Your device does not appear to be on there. Until he has the time to add new devices, your best option would be to fork his driver and try adding the fingerprint yourself. The code for similar devices would probably work. I had to do the same to gain functionality for some newer switches.
