Thanks for the reply @ygerlovin. I was hoping that the fingerprint of the one I have would work since the fingerprint of the one in your first post are so similar.
@johnconstantelo
Aqara often use proprietary messages and they might be different even for models that look very similar.
I will try to take a quick look at yours and will see what can be done
@troy_owens
While EF00 use a fixed format messages for everything (as far as I could see) each device might use different values (dpid) for different capabilities.
I will see whether I can find the required info on different forums, like deconz or hubitat to correctly decode the messages
@ygerlovin you can check for Tuya EF00 Data Points for this device here. Although he manufacturer is different, hopefully the DPs are the same.
but ā¦
@troy_owens I really do not recommend this device joined to your ST Zigbee network. It sends data updates so frequently, so it can overload your Zigbee mesh very easily. I have a device from another manufacturer (_TZE200_yvx5lh6k), but if yours has the same behavior - better return it if you can. Mine sits unused in my junk drawer, I use it occasionally just for stress testing my Zigbee mesh.
I did find a working Hubitat driverā¦ I tried to reverse engineer it myself but my coding skills arenāt up to par. Iāve been fiddling with it for some time. Raphael Borja had started it in his ST driver repo but didnāt finish. Maybe you could get some clues from those 2. Thanks in advance for your effort whether you accomplish it or not.
Thanks for the heads up. At this point it has become a challenge and would just like to get it working if only for a while. Spent a lot of time trying to code it myself and it wasnāt expensive so one way or another it may end up in a drawer. Lol
Hi @ygerlovin,
Great work on making this edge driver!
Would you consider adding the fingerprint for the basic motion sensor, RTCGQ01LM?
From IDE:
* application: **0B**
* endpointId: **01**
* manufacturer: **LUMI**
* model: **lumi.sensor_motion**
* zigbeeNodeType: **SLEEPY_END_DEVICE**
Raw description:
01 0104 0104 01 04 0000 0003 FFFF 0019 07 0000 0004 0003 0006 0008 0005 0019
From the DTH by a4refillpad:
fingerprint profileId: "0104", deviceId: "0104", inClusters: "0000, 0003, FFFF, 0019", outClusters: "0000, 0004, 0003, 0006, 0008, 0005, 0019", manufacturer: "LUMI", model: "lumi.sensor_motion", deviceJoinName: "Xiaomi Motion"
If there is anything I can do to help, please tell me.
Hi all,
There were several requests to add devices lately, so please let me recap to make sure I donāt miss anything.
Tuya presence sensor _TZE200_ikvncluo/TS0601 from @jw970065 [ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver - #196 by jw970065
Aqara vibration sensor LUMI/lumi.vibration.agl01 from @johnconstantelo
[ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver - #211 by johnconstantelo -
Aquara temp/humidity sensor LUMI/lumi.sens from @d3fung [ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver - #258 by d3fung
Tuya Air Quality Sensor _TZE200_dwcarsat/TS0601 from @troy_owens
[ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver - #264 by troy_owens -
Aqara Motion sensor LUMI/lumi.sensor_motion from @stones
[ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver - #272 by stones
Also, some improvments for already supported devices
- Missing functionality for Aqara vibration sensor LUMI/lumi.vibration.aq1 from @montyfert
- Aqara FP1 - faster detection + maps
Did I miss anything?
Cheers,
Yakov
Thanks for that summary @ygerlovin, your efforts are very much and always appreciated! Thanks for considering that other vibration sensor.
thank you
martin
I think Iām all set. I found this repo/channel that has the humidity sensor GitHub - veonua/SmartThingsEdge-Xiaomi: SmartThings Edge drivers for XIaomi and Aqara devices. The model is actually lumi.sensor_ht. The web ide truncated the model name for some reason.
The model that I am not happy with is the old round one.
Letās hope that the newer model will behave better.
I bought this one specifically for the fine dust level (pm2. 5) capability absent in the others.
Thank you for expressing your interest.
The details of No. 1 are correct that I requested.
I think it would be good if you could put in the wall type sensor with the same structure.
endpointId: 01
model: TS0601
application: 41
manufacturer: _TZE200_ztc6ggyl
Do you know if there is a driver for this one?
Data
- application: 05
- endpointId: 01
- manufacturer: LUMI
- model: lumi.weather
- zigbeeNodeType: SLEEPY_END_DEVICE
