13 lm
The driver is offline on aΔΊl my Xiaomi Window and Door Sensors.
Hi @Gruv_Shack
If the door/window is opened, does the sensor detects it?
Does it get online?
What model do you have?
First of all, I want to say thank you.
This sensor is the best sensor with better performance than aqara-fp1.
So many people are hoping to use it for ST.
- endpointId: 01
- model: TS0601
- application: 44
- manufacturer: _TZE200_ikvncluo
fingerprint profileId:β0104β, endpointId:β01β, inClusters:β0000,0004,0005,EF00β, outClusters:β0019,000Aβ, model:βTS0601β, manufacturer:β_TZE200_ikvncluoβ, deviceJoinName: βMoes TuyaHuman Presence Detector Radar 2 in 1β
The Hubitat developer made it available for use in Hubitat. Please refer to it.
He is a very good developer who is very interested in presence sensors.
The last log file was sent by mail because there was a limit to the number of responses.
[details=βSummaryβ]
Device pairing info
Manufacturer: | _TZE200_ikvncluo |
Endpoint 01 application: | 44 |
Endpoint 01 endpointId: | 01 |
Endpoint 01 idAsInt: | 1 |
Endpoint 01 inClusters: | 0000,0004,0005,EF00 |
Endpoint 01 initialized: | true |
Endpoint 01 manufacturer: | _TZE200_ikvncluo |
Endpoint 01 model: | TS0601 |
Endpoint 01 outClusters: | 0019,000A |
Endpoint 01 profileId: | 0104 |
Endpoint 01 stage: | 4 |
Summary
dev:47942022-07-27 08:14:28.869 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:28.868 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:28.863 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 005A0302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5A, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:28.814 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:28.810 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:26.908 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:26.907 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:26.903 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0059660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 59, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:26.864 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:26.861 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:26.673 pm infoμκ΄λ¦¬μ€ stay Radar Maximum detection distance is 4 m
dev:47942022-07-27 08:14:26.672 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=4 fncmd=400
dev:47942022-07-27 08:14:26.669 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00580402000400000190, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 58, 04, 02, 00, 04, 00, 00, 01, 90]]
dev:47942022-07-27 08:14:26.642 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:26.639 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:25.814 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=0
dev:47942022-07-27 08:14:25.810 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00570902000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 57, 09, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:25.672 pm infoμκ΄λ¦¬μ€ stay Motion reset to inactive after 55s
dev:47942022-07-27 08:14:25.671 pm debugμκ΄λ¦¬μ€ stay (DP=0x01) motion event fncmd = 0
dev:47942022-07-27 08:14:25.670 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=1 fncmd=0
dev:47942022-07-27 08:14:25.667 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00560104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 56, 01, 04, 00, 01, 00]]
dev:47942022-07-27 08:14:25.540 pm infoμκ΄λ¦¬μ€ stay (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:14:25.539 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:14:25.535 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00556502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 55, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:14:25.405 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:25.404 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:25.400 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00540302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 54, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:25.248 pm infoμκ΄λ¦¬μ€ stay illuminance is 23 Lux
dev:47942022-07-27 08:14:25.246 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=104 fncmd=23
dev:47942022-07-27 08:14:25.243 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00536802000400000017, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 53, 68, 02, 00, 04, 00, 00, 00, 17]]
dev:47942022-07-27 08:14:25.045 pm infoμκ΄λ¦¬μ€ stay Radar DP_103 (Debug CLI) is 32
dev:47942022-07-27 08:14:25.044 pm debugμκ΄λ¦¬μ€ stay dp_id=3 dp=103 fncmd=32
dev:47942022-07-27 08:14:25.041 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00526703000120, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 52, 67, 03, 00, 01, 20]]
dev:47942022-07-27 08:14:24.889 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=111
dev:47942022-07-27 08:14:24.886 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0051090200040000006F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 51, 09, 02, 00, 04, 00, 00, 00, 6F]]
dev:47942022-07-27 08:14:24.806 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:24.804 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:24.705 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:24.704 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:24.701 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0050660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 50, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:24.634 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:24.631 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:24.531 pm infoμκ΄λ¦¬μ€ stay (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:14:24.530 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:14:24.526 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004F6502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4F, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:14:24.415 pm infoμκ΄λ¦¬μ€ stay Radar self checking status is 1
dev:47942022-07-27 08:14:24.415 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=6 fncmd=1
dev:47942022-07-27 08:14:24.411 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004E0604000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4E, 06, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:24.295 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:24.294 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:24.291 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004D0302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4D, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:24.181 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:24.180 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:24.176 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004C0202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4C, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:24.072 pm infoμκ΄λ¦¬μ€ stay Radar Maximum detection distance is 4 m
dev:47942022-07-27 08:14:24.071 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=4 fncmd=400
dev:47942022-07-27 08:14:24.068 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004B0402000400000190, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4B, 04, 02, 00, 04, 00, 00, 01, 90]]
dev:47942022-07-27 08:14:23.964 pm infoμκ΄λ¦¬μ€ stay Motion is active 53s
dev:47942022-07-27 08:14:23.963 pm debugμκ΄λ¦¬μ€ stay (DP=0x01) motion event fncmd = 1
dev:47942022-07-27 08:14:23.962 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=1 fncmd=1
dev:47942022-07-27 08:14:23.958 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 004A0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4A, 01, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:23.116 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=111
dev:47942022-07-27 08:14:23.110 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0049090200040000006F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 49, 09, 02, 00, 04, 00, 00, 00, 6F]]
dev:47942022-07-27 08:14:22.875 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:22.874 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:22.869 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00480202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 48, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:22.854 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:22.845 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:22.749 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:22.748 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:22.743 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0047660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 47, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:22.729 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:22.725 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:22.680 pm infoμκ΄λ¦¬μ€ stay preferencies updates are sent to the deviceβ¦
dev:47942022-07-27 08:14:22.673 pm debugμκ΄λ¦¬μ€ stay sendZigbeeCommands (cmd=[he cmd 0xD410 0x01 0xEF00 0x00 {000B0202000400000003}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {000C6502000400000001}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {000D660200040000000A}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {000E0302000400000000}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {000F0402000400000190}, delay 2000])
dev:47942022-07-27 08:14:22.672 pm debugμκ΄λ¦¬μ€ stay sending the changed AdvancedOptions
dev:47942022-07-27 08:14:22.659 pm warnμκ΄λ¦¬μ€ stay changing radar maximum distance to : 4 (400)
dev:47942022-07-27 08:14:22.658 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000F0402000400000190}, delay 2000]
dev:47942022-07-27 08:14:22.653 pm warnμκ΄λ¦¬μ€ stay changing radar minimum distance to 0 (0)
dev:47942022-07-27 08:14:22.651 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000E0302000400000000}, delay 2000]
dev:47942022-07-27 08:14:22.648 pm warnμκ΄λ¦¬μ€ stay changing radar fading time to 1 seconds (10)
dev:47942022-07-27 08:14:22.646 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000D660200040000000A}, delay 2000]
dev:47942022-07-27 08:14:22.643 pm warnμκ΄λ¦¬μ€ stay changing radar detection delay to 0.1 seconds (1)
dev:47942022-07-27 08:14:22.641 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000C6502000400000001}, delay 2000]
dev:47942022-07-27 08:14:22.637 pm warnμκ΄λ¦¬μ€ stay changing radar sensitivity to : 3.0
dev:47942022-07-27 08:14:22.636 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000B0202000400000003}, delay 2000]
dev:47942022-07-27 08:14:22.632 pm debugμκ΄λ¦¬μ€ stay Config parameters changed! old=bd24320921759bda2c21bd new=bd24320921759bda2c21bd
dev:47942022-07-27 08:14:22.624 pm infoμκ΄λ¦¬μ€ stay Debug logging is will be turned off after 24 hours
dev:47942022-07-27 08:14:22.584 pm infoμκ΄λ¦¬μ€ stay Debug logging is true; Description text logging is true
dev:47942022-07-27 08:14:22.582 pm infoμκ΄λ¦¬μ€ stay Updating μκ΄λ¦¬μ€ stay (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_ikvncluo
dev:47942022-07-27 08:14:22.103 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=112
dev:47942022-07-27 08:14:22.100 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00460902000400000070, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 46, 09, 02, 00, 04, 00, 00, 00, 70]]
This is the second log file.
Summary
dev:47942022-07-27 08:14:19.108 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=148
dev:47942022-07-27 08:14:19.104 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00410902000400000094, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 41, 09, 02, 00, 04, 00, 00, 00, 94]]
dev:47942022-07-27 08:14:18.846 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:18.846 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:18.842 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00400202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 40, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:18.733 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:18.733 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:18.729 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003F0302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3F, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:18.641 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:18.638 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:18.592 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=112
dev:47942022-07-27 08:14:18.588 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003E0902000400000070, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3E, 09, 02, 00, 04, 00, 00, 00, 70]]
dev:47942022-07-27 08:14:18.525 pm infoμκ΄λ¦¬μ€ stay illuminance is 23 Lux
dev:47942022-07-27 08:14:18.523 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=104 fncmd=23
dev:47942022-07-27 08:14:18.520 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003D6802000400000017, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3D, 68, 02, 00, 04, 00, 00, 00, 17]]
dev:47942022-07-27 08:14:18.504 pm infoμκ΄λ¦¬μ€ stay preferencies updates are sent to the deviceβ¦
dev:47942022-07-27 08:14:18.498 pm debugμκ΄λ¦¬μ€ stay sendZigbeeCommands (cmd=[he cmd 0xD410 0x01 0xEF00 0x00 {00060202000400000003}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {00076502000400000001}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {0008660200040000000A}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {00090302000400000000}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {000A0402000400000190}, delay 2000])
dev:47942022-07-27 08:14:18.498 pm debugμκ΄λ¦¬μ€ stay sending the changed AdvancedOptions
dev:47942022-07-27 08:14:18.491 pm warnμκ΄λ¦¬μ€ stay changing radar maximum distance to : 4 (400)
dev:47942022-07-27 08:14:18.490 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {000A0402000400000190}, delay 2000]
dev:47942022-07-27 08:14:18.487 pm warnμκ΄λ¦¬μ€ stay changing radar minimum distance to 0 (0)
dev:47942022-07-27 08:14:18.486 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00090302000400000000}, delay 2000]
dev:47942022-07-27 08:14:18.483 pm warnμκ΄λ¦¬μ€ stay changing radar fading time to 1 seconds (10)
dev:47942022-07-27 08:14:18.482 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {0008660200040000000A}, delay 2000]
dev:47942022-07-27 08:14:18.479 pm warnμκ΄λ¦¬μ€ stay changing radar detection delay to 0.1 seconds (1)
dev:47942022-07-27 08:14:18.478 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00076502000400000001}, delay 2000]
dev:47942022-07-27 08:14:18.475 pm warnμκ΄λ¦¬μ€ stay changing radar sensitivity to : 3.0
dev:47942022-07-27 08:14:18.474 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00060202000400000003}, delay 2000]
dev:47942022-07-27 08:14:18.471 pm debugμκ΄λ¦¬μ€ stay Config parameters changed! old=bd24320921759bda2c21bd new=bd24320921759bda2c21bd
dev:47942022-07-27 08:14:18.466 pm infoμκ΄λ¦¬μ€ stay Debug logging is will be turned off after 24 hours
dev:47942022-07-27 08:14:18.435 pm infoμκ΄λ¦¬μ€ stay Debug logging is true; Description text logging is true
dev:47942022-07-27 08:14:18.433 pm infoμκ΄λ¦¬μ€ stay Updating μκ΄λ¦¬μ€ stay (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_ikvncluo
dev:47942022-07-27 08:14:18.344 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:18.341 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:18.228 pm infoμκ΄λ¦¬μ€ stay Radar DP_103 (Debug CLI) is 32
dev:47942022-07-27 08:14:18.228 pm debugμκ΄λ¦¬μ€ stay dp_id=3 dp=103 fncmd=32
dev:47942022-07-27 08:14:18.224 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003C6703000120, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3C, 67, 03, 00, 01, 20]]
dev:47942022-07-27 08:14:18.123 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=109
dev:47942022-07-27 08:14:18.119 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003B090200040000006D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3B, 09, 02, 00, 04, 00, 00, 00, 6D]]
dev:47942022-07-27 08:14:18.007 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:18.006 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:18.001 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 003A660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3A, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:17.847 pm infoμκ΄λ¦¬μ€ stay (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:14:17.845 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:14:17.840 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00396502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 39, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:14:17.729 pm infoμκ΄λ¦¬μ€ stay Radar self checking status is 1
dev:47942022-07-27 08:14:17.728 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=6 fncmd=1
dev:47942022-07-27 08:14:17.725 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00380604000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 38, 06, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:17.601 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:17.600 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:17.596 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00370302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 37, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:17.474 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:17.473 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:17.468 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00360202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 36, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:17.330 pm infoμκ΄λ¦¬μ€ stay Radar Maximum detection distance is 4 m
dev:47942022-07-27 08:14:17.328 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=4 fncmd=400
dev:47942022-07-27 08:14:17.324 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00350402000400000190, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 35, 04, 02, 00, 04, 00, 00, 01, 90]]
dev:47942022-07-27 08:14:17.213 pm infoμκ΄λ¦¬μ€ stay Motion is active 47s
dev:47942022-07-27 08:14:17.211 pm debugμκ΄λ¦¬μ€ stay (DP=0x01) motion event fncmd = 1
dev:47942022-07-27 08:14:17.210 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=1 fncmd=1
dev:47942022-07-27 08:14:17.206 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00340104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 34, 01, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:16.411 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:16.410 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:16.406 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0033660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 33, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:16.331 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:16.328 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:16.107 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=109
dev:47942022-07-27 08:14:16.103 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0032090200040000006D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 32, 09, 02, 00, 04, 00, 00, 00, 6D]]
dev:47942022-07-27 08:14:15.145 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=141
dev:47942022-07-27 08:14:15.102 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0031090200040000008D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 31, 09, 02, 00, 04, 00, 00, 00, 8D]]
dev:47942022-07-27 08:14:14.366 pm infoμκ΄λ¦¬μ€ stay (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:14:14.365 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:14:14.361 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00306502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 30, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:14:14.343 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:14.339 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:14.122 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=220
dev:47942022-07-27 08:14:14.118 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002F09020004000000DC, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2F, 09, 02, 00, 04, 00, 00, 00, DC]]
dev:47942022-07-27 08:14:13.120 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=135
dev:47942022-07-27 08:14:13.113 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002E0902000400000087, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2E, 09, 02, 00, 04, 00, 00, 00, 87]]
dev:47942022-07-27 08:14:12.370 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:12.367 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:12.364 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002D0202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2D, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:12.335 pm debugμκ΄λ¦¬μ€ stay device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:47942022-07-27 08:14:12.332 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:47942022-07-27 08:14:12.193 pm infoμκ΄λ¦¬μ€ stay preferencies updates are sent to the deviceβ¦
dev:47942022-07-27 08:14:12.186 pm debugμκ΄λ¦¬μ€ stay sendZigbeeCommands (cmd=[he cmd 0xD410 0x01 0xEF00 0x00 {00010202000400000003}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {00026502000400000001}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {0003660200040000000A}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {00040302000400000000}, delay 2000, he cmd 0xD410 0x01 0xEF00 0x00 {00050402000400000190}, delay 2000])
dev:47942022-07-27 08:14:12.185 pm debugμκ΄λ¦¬μ€ stay sending the changed AdvancedOptions
dev:47942022-07-27 08:14:12.176 pm warnμκ΄λ¦¬μ€ stay changing radar maximum distance to : 4 (400)
dev:47942022-07-27 08:14:12.174 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00050402000400000190}, delay 2000]
dev:47942022-07-27 08:14:12.170 pm warnμκ΄λ¦¬μ€ stay changing radar minimum distance to 0 (0)
dev:47942022-07-27 08:14:12.169 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00040302000400000000}, delay 2000]
dev:47942022-07-27 08:14:12.165 pm warnμκ΄λ¦¬μ€ stay changing radar fading time to 1 seconds (10)
dev:47942022-07-27 08:14:12.163 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {0003660200040000000A}, delay 2000]
dev:47942022-07-27 08:14:12.160 pm warnμκ΄λ¦¬μ€ stay changing radar detection delay to 0.1 seconds (1)
dev:47942022-07-27 08:14:12.159 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00026502000400000001}, delay 2000]
dev:47942022-07-27 08:14:12.156 pm warnμκ΄λ¦¬μ€ stay changing radar sensitivity to : 3.0
dev:47942022-07-27 08:14:12.155 pm debugμκ΄λ¦¬μ€ stay sendTuyaCommand = [he cmd 0xD410 0x01 0xEF00 0x00 {00010202000400000003}, delay 2000]
dev:47942022-07-27 08:14:12.151 pm debugμκ΄λ¦¬μ€ stay Config parameters changed! old=bdbdbdbdbdbdbdbdbdbdbd new=bd24320921759bda2c21bd
dev:47942022-07-27 08:14:12.144 pm infoμκ΄λ¦¬μ€ stay Debug logging is will be turned off after 24 hours
dev:47942022-07-27 08:14:12.116 pm infoμκ΄λ¦¬μ€ stay Debug logging is true; Description text logging is true
dev:47942022-07-27 08:14:12.115 pm infoμκ΄λ¦¬μ€ stay Updating μκ΄λ¦¬μ€ stay (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_ikvncluo
dev:47942022-07-27 08:14:12.106 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=110
dev:47942022-07-27 08:14:12.103 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002C090200040000006E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2C, 09, 02, 00, 04, 00, 00, 00, 6E]]
dev:47942022-07-27 08:14:11.106 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=132
This is the third log file.
Summary
dev:47942022-07-27 08:14:11.103 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002B0902000400000084, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2B, 09, 02, 00, 04, 00, 00, 00, 84]]
dev:47942022-07-27 08:14:10.107 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=122
dev:47942022-07-27 08:14:10.104 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 002A090200040000007A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2A, 09, 02, 00, 04, 00, 00, 00, 7A]]
dev:47942022-07-27 08:14:09.107 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=119
dev:47942022-07-27 08:14:09.103 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00290902000400000077, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 29, 09, 02, 00, 04, 00, 00, 00, 77]]
dev:47942022-07-27 08:14:08.461 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=122
dev:47942022-07-27 08:14:08.457 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0028090200040000007A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 28, 09, 02, 00, 04, 00, 00, 00, 7A]]
dev:47942022-07-27 08:14:08.333 pm infoμκ΄λ¦¬μ€ stay illuminance is 23 Lux
dev:47942022-07-27 08:14:08.332 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=104 fncmd=23
dev:47942022-07-27 08:14:08.328 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00276802000400000017, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 27, 68, 02, 00, 04, 00, 00, 00, 17]]
dev:47942022-07-27 08:14:08.217 pm infoμκ΄λ¦¬μ€ stay Radar DP_103 (Debug CLI) is 32
dev:47942022-07-27 08:14:08.216 pm debugμκ΄λ¦¬μ€ stay dp_id=3 dp=103 fncmd=32
dev:47942022-07-27 08:14:08.212 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00266703000120, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 26, 67, 03, 00, 01, 20]]
dev:47942022-07-27 08:14:08.178 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=126
dev:47942022-07-27 08:14:08.098 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0025090200040000007E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 25, 09, 02, 00, 04, 00, 00, 00, 7E]]
dev:47942022-07-27 08:14:07.981 pm infoμκ΄λ¦¬μ€ stay (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:14:07.980 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:14:07.976 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0024660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 24, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:14:07.871 pm infoμκ΄λ¦¬μ€ stay (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:14:07.869 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:14:07.865 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00236502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 23, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:14:07.750 pm infoμκ΄λ¦¬μ€ stay Radar self checking status is 1
dev:47942022-07-27 08:14:07.749 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=6 fncmd=1
dev:47942022-07-27 08:14:07.746 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00220604000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 22, 06, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:07.628 pm infoμκ΄λ¦¬μ€ stay (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:14:07.627 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:14:07.623 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00210302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 21, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:14:07.505 pm infoμκ΄λ¦¬μ€ stay Radar sensitivity is 3
dev:47942022-07-27 08:14:07.504 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:14:07.499 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00200202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 20, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:14:07.346 pm infoμκ΄λ¦¬μ€ stay Radar Maximum detection distance is 4 m
dev:47942022-07-27 08:14:07.345 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=4 fncmd=400
dev:47942022-07-27 08:14:07.341 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001F0402000400000190, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1F, 04, 02, 00, 04, 00, 00, 01, 90]]
dev:47942022-07-27 08:14:07.227 pm infoμκ΄λ¦¬μ€ stay Motion is active 37s
dev:47942022-07-27 08:14:07.226 pm debugμκ΄λ¦¬μ€ stay (DP=0x01) motion event fncmd = 1
dev:47942022-07-27 08:14:07.225 pm debugμκ΄λ¦¬μ€ stay dp_id=4 dp=1 fncmd=1
dev:47942022-07-27 08:14:07.221 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001E0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1E, 01, 04, 00, 01, 01]]
dev:47942022-07-27 08:14:07.104 pm debugμκ΄λ¦¬μ€ stay dp_id=2 dp=9 fncmd=126
dev:47942022-07-27 08:14:07.101 pm debugμκ΄λ¦¬μ€ stay parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001D090200040000007E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1D, 09, 02, 00, 04, 00, 00, 00, 7E]]
dev:47942022-07-27 08:14:05.110 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=110
dev:47942022-07-27 08:14:05.106 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001C090200040000006E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1C, 09, 02, 00, 04, 00, 00, 00, 6E]]
dev:47942022-07-27 08:14:04.112 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=100
dev:47942022-07-27 08:14:04.106 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001B0902000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1B, 09, 02, 00, 04, 00, 00, 00, 64]]
dev:47942022-07-27 08:14:03.116 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=116
dev:47942022-07-27 08:14:03.112 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001A0902000400000074, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1A, 09, 02, 00, 04, 00, 00, 00, 74]]
dev:47942022-07-27 08:14:02.115 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=220
dev:47942022-07-27 08:14:02.111 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001909020004000000DC, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 19, 09, 02, 00, 04, 00, 00, 00, DC]]
dev:47942022-07-27 08:14:01.107 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=257
dev:47942022-07-27 08:14:01.104 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00180902000400000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 18, 09, 02, 00, 04, 00, 00, 01, 01]]
dev:47942022-07-27 08:14:00.107 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=132
dev:47942022-07-27 08:14:00.104 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00170902000400000084, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 17, 09, 02, 00, 04, 00, 00, 00, 84]]
dev:47942022-07-27 08:13:59.107 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=186
dev:47942022-07-27 08:13:59.104 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 001609020004000000BA, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 16, 09, 02, 00, 04, 00, 00, 00, BA]]
dev:47942022-07-27 08:13:58.403 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=289
dev:47942022-07-27 08:13:58.399 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00150902000400000121, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 15, 09, 02, 00, 04, 00, 00, 01, 21]]
dev:47942022-07-27 08:13:58.275 pm infoTuya Multi Sensor 4 In 1 illuminance is 23 Lux
dev:47942022-07-27 08:13:58.274 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=104 fncmd=23
dev:47942022-07-27 08:13:58.270 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00146802000400000017, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 14, 68, 02, 00, 04, 00, 00, 00, 17]]
dev:47942022-07-27 08:13:58.163 pm infoTuya Multi Sensor 4 In 1 Radar DP_103 (Debug CLI) is 32
dev:47942022-07-27 08:13:58.162 pm debugTuya Multi Sensor 4 In 1 dp_id=3 dp=103 fncmd=32
dev:47942022-07-27 08:13:58.159 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00136703000120, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 13, 67, 03, 00, 01, 20]]
dev:47942022-07-27 08:13:58.048 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=343
dev:47942022-07-27 08:13:58.044 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00120902000400000157, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 12, 09, 02, 00, 04, 00, 00, 01, 57]]
dev:47942022-07-27 08:13:57.931 pm infoTuya Multi Sensor 4 In 1 (dp=102) reported Radar fading time is 1 seconds (10)
dev:47942022-07-27 08:13:57.930 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=102 fncmd=10
dev:47942022-07-27 08:13:57.927 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0011660200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 11, 66, 02, 00, 04, 00, 00, 00, 0A]]
dev:47942022-07-27 08:13:57.821 pm infoTuya Multi Sensor 4 In 1 (dp=101) reported Radar detection delay is 0.1 seconds (1)
dev:47942022-07-27 08:13:57.820 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=101 fncmd=1
dev:47942022-07-27 08:13:57.816 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00106502000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 10, 65, 02, 00, 04, 00, 00, 00, 01]]
dev:47942022-07-27 08:13:57.783 pm infoTuya Multi Sensor 4 In 1 Radar self checking status is 1
dev:47942022-07-27 08:13:57.781 pm debugTuya Multi Sensor 4 In 1 dp_id=4 dp=6 fncmd=1
dev:47942022-07-27 08:13:57.777 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000F0604000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0F, 06, 04, 00, 01, 01]]
dev:47942022-07-27 08:13:57.586 pm infoTuya Multi Sensor 4 In 1 (dp=3) reported Radar Minimum detection distance is 0 m
dev:47942022-07-27 08:13:57.585 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=3 fncmd=0
dev:47942022-07-27 08:13:57.580 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000E0302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0E, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:47942022-07-27 08:13:57.457 pm infoTuya Multi Sensor 4 In 1 Radar sensitivity is 3
dev:47942022-07-27 08:13:57.456 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=2 fncmd=3
dev:47942022-07-27 08:13:57.451 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000D0202000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0D, 02, 02, 00, 04, 00, 00, 00, 03]]
dev:47942022-07-27 08:13:57.341 pm infoTuya Multi Sensor 4 In 1 Radar Maximum detection distance is 4 m
dev:47942022-07-27 08:13:57.339 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=4 fncmd=400
dev:47942022-07-27 08:13:57.335 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000C0402000400000190, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0C, 04, 02, 00, 04, 00, 00, 01, 90]]
dev:47942022-07-27 08:13:57.232 pm infoTuya Multi Sensor 4 In 1 Motion is active 27s
dev:47942022-07-27 08:13:57.230 pm debugTuya Multi Sensor 4 In 1 (DP=0x01) motion event fncmd = 1
dev:47942022-07-27 08:13:57.229 pm debugTuya Multi Sensor 4 In 1 dp_id=4 dp=1 fncmd=1
dev:47942022-07-27 08:13:57.225 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000B0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0B, 01, 04, 00, 01, 01]]
dev:47942022-07-27 08:13:57.118 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=343
dev:47942022-07-27 08:13:57.114 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 000A0902000400000157, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0A, 09, 02, 00, 04, 00, 00, 01, 57]]
dev:47942022-07-27 08:13:56.107 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=282
dev:47942022-07-27 08:13:56.103 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 0009090200040000011A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 09, 09, 02, 00, 04, 00, 00, 01, 1A]]
dev:47942022-07-27 08:13:55.106 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=137
dev:47942022-07-27 08:13:55.103 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00080902000400000089, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 08, 09, 02, 00, 04, 00, 00, 00, 89]]
dev:47942022-07-27 08:13:54.955 pm warnTuya Multi Sensor 4 In 1 NOT PROCESSED Tuya descMap?.command = 11 cmd: dp=null value=null descMap.data = [00, 0A, 84]
dev:47942022-07-27 08:13:54.952 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 11 01 000A84, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 0A, 84]]
dev:47942022-07-27 08:13:54.115 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=133
dev:47942022-07-27 08:13:54.111 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00070902000400000085, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 07, 09, 02, 00, 04, 00, 00, 00, 85]]
dev:47942022-07-27 08:13:53.116 pm debugTuya Multi Sensor 4 In 1 dp_id=2 dp=9 fncmd=128
dev:47942022-07-27 08:13:53.112 pm debugTuya Multi Sensor 4 In 1 parse(_TZE200_ikvncluo) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 D410 01 00 0000 01 01 00060902000400000080, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D410, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 06, 09, 02, 00, 04, 00, 00, 00, 80]]
βββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β vibration sensor β
β Id β 3fad5e39-dd69-4201-bba8-ae63fdff4be5 β
β Label β vibration sensor β
β Manufacturer Code β LUMI β
β Location Id β 99c131a4-42fa-4c93-bade-a013f5c02732 β
β Room Id β β
β Device Type Id β β
β main component β battery β
β β contactSensor β
β β motionSensor β
β β threeAxis β
β β accelerationSensor β
β β button β
β β sensor β
β β healthCheck β
β β circlemusic21301.setClosed β
β β circlemusic21301.setOpen β
β β circlemusic21301.activityLevel β
β Child Devices β β
β Profile Id β β
β Installed App Id β β
β External App Id β β
β App Profile Id β β
βββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
ββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββ¬βββββββββββββββββββββββ
β Capability β Attribute β Value β
ββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββΌβββββββββββββββββββββββ€
β button β button β βpushedβ β
β button β numberOfButtons β 1 β
β button β supportedButtonValues β [βpushedβ,βdown_6xβ] β
β contactSensor β contact β βclosedβ β
β threeAxis β threeAxis β [2.3,-0.9,87.5] mG β
β healthCheck β checkInterval β 86400 s β
β healthCheck β healthStatus β β
β healthCheck β DeviceWatch-Enroll β β
β healthCheck β DeviceWatch-DeviceStatus β β
β motionSensor β motion β βinactiveβ β
β battery β battery β 99 % β
β circlemusic21301.activityLevel β activitylevel β 31 β
β accelerationSensor β acceleration β βinactiveβ β
ββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββ΄βββββββββββββββββββββββ
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:44 PM: info vibration sensor [vibration sensor] [mapsensorevent] 4
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:44 PM: info vibration sensor [vibration sensor] [clearvibration]
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:40 PM: info vibration sensor [vibration sensor] [parse] [name:acceleration, value:active, descriptionText:Vibration (acceleration)]
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:40 PM: info vibration sensor [vibration sensor] [mapsensorevent] 1
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:40 PM: info vibration sensor [vibration sensor] [readattr]
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:40 PM: debug vibration sensor [vibration sensor] [parse] read attr - raw: 10690101010A5500210100, dni: 1069, endpoint: 01, cluster: 0101, size: 10, attrId: 0055, result: success, encoding: 21, value: 0001
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:32 PM: info vibration sensor [vibration sensor] [parse] [name:battery, value:99, unit:%, isStateChange:true]
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:32 PM: info vibration sensor [vibration sensor] [battery] 3.195 V
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:32 PM: debug vibration sensor [vibration sensor] [catchall] SmartShield(text: null, manufacturerId: 0x115f, direction: 0x01, data: [0x01, 0xff, 0x42, 0x2e, 0x01, 0x21, 0x7b, 0x0c, 0x03, 0x28, 0x1e, 0x04, 0x21, 0xa8, 0x43, 0x05, 0x21, 0x82, 0x03, 0x06, 0x24, 0x07, 0x00, 0x00, 0x00, 0x00, 0x08, 0x21, 0x08, 0x03, 0x0a, 0x21, 0x97, 0x00, 0x98, 0x21, 0x28, 0x00, 0x99, 0x21, 0xa6, 0x00, 0x9a, 0x25, 0x6c, 0x00, 0x02, 0x00, 0xaa, 0x04], number: null, isManufacturerSpecific: true, messageType: 0x00, senderShortId: 0x1069, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x0a, clusterId: 0x0000, destinationEndpoint: 0x01, options: 0x0000)
3fad5e39-dd69-4201-bba8-ae63fdff4be5 9:17:32 PM: info vibration sensor [vibration sensor] [catchall]
Sorry for late reply.
- It wasnβt working at all.
- Nope but it came online unexpectedly.
- See attached image
Thanks for your timeβ¦
Hi,
Is it possible to add this LCD display version of a Tuya compatible Temperature & Humidity sensor to your driver?
Hi
I have visual exactly the same hum/temp sensor and iβm using edge driver βzigbee tem humidity mcβ without problems. Try it or ask Mariano to add fingerprints.
Hi @rubberduck72 ,
I added _TZ2000_a476raq2/TS0201 to the driver v1.8.0.
Would it be possible to provide logs that show battery reporting?
Hi @rubberduck72,
This device is added to Zigbee Temp Humidity Sensor Mc some time ago.
you can use this or @ygerlovin driver, whatever you want
- id: "Tuya/TS0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ2000_a476raq2
model: TS0201
deviceProfileName: temp-humid-battery
Hi @ygerlovin
Thankyou for adding, device added, but tile in app keeps showing βcheckingβ and no data is parsed through.
I then tried to add and switched to @Mariano_Colmenarejo βZigbee Temp Humidity Sensor Mcβ driver as advised by @dusanhauko and now it works and shows data and battery correct.
@ygerlovin @veonua
I would like to know if you are planning to make a driver for the aqara curtain motor, the E1 modelβ¦
Thank you for everything you do for the community!
some driver from Aqara is already in the ST GitHub .
- id: βLUMI/lumi.curtainβ
deviceLabel: Aqara Curtain Controller
manufacturer: LUMI
model: lumi.curtain
deviceProfileName: window-treatment-aqara - id: βLUMI/lumi.curtain.v1β
manufacturer: LUMI
model: lumi.curtain.v1
Many thanks! Had the P1 but couldnβt add it last time I checked. And now down to 1 LED controller that doesnβt uses Edge yet.
Thank you very much!
@ygerlovin I just wanted to say thank you for providing this. Not only was I able to (finally!) get my Aqara vibration sensor into SmartThings, but I got two FP1 sensors and they loaded like magic! Thank you!
