The Aqara Power Plug H2 EU (RGB) is one of Aqara’s newer dual-protocol smart plugs for the European market. It can operate either as a Matter-over-Thread device or as a Zigbee 3.0 device, and the RGB version combines a 16 A smart plug with energy monitoring, protection features and a fully controllable RGB indicator ring.
The relevant device identifiers are:
- Product: Aqara Power Plug H2 EU (RGB)
- Retail model:
SP-P05D - Zigbee model:
lumi.plug.aeu005 - Wireless protocols: Thread, Zigbee and BLE
- Electrical rating: 100–240 VAC, 50/60 Hz, up to 16 A
- Maximum resistive load: 3680 W at 230 V
- Socket: Type E/F
- Network role: Zigbee router or Thread router, depending on the selected protocol
Aqara also offers a non-RGB version, the SP-P05E. Current production firmware information identifies that model as lumi.plug.aeu004, while the RGB SP-P05D uses lumi.plug.aeu005.
In addition to normal on/off control, the SP-P05D monitors electrical consumption, provides overload and overheat protection, supports charging protection and a child lock, and includes an RGB indicator that can be used either as a normal colored light or as a visual representation of energy consumption.
Matter or Zigbee?
The H2 EU RGB can be connected directly to SmartThings through Matter over Thread, so a custom driver is not required for basic integration. Current H2 firmware also supports the Matter energy-measurement clusters introduced with Matter 1.3, and SmartThings can display Matter energy data.
Zigbee becomes interesting when the Aqara-specific configuration options are wanted. Aqara documents several functions as Zigbee-only, including the configurable load limit, advanced indicator behavior and the RGB energy-visualization modes. This Edge driver accesses those Zigbee functions directly from a SmartThings Hub, without requiring an Aqara hub after the plug has been placed in Zigbee mode.
The table below compares the practical SmartThings experience rather than every internal capability of the hardware:
| Feature in SmartThings | Matter over Thread | Zigbee with this Edge driver |
| Socket on/off | Yes | Yes |
| Local operation | Yes | Yes |
| Direct SmartThings integration without an Aqara hub | Yes | Yes |
| Required mesh infrastructure | Matter Controller + Thread Border Router | SmartThings Hub with Zigbee |
| Mesh-router role | Thread router | Zigbee router |
| Real-time power | Yes, with current Matter firmware | Yes |
| Accumulated energy | Yes, with current Matter firmware | Yes |
| Current measurement | Yes, with current Matter firmware | Yes |
| Voltage measurement | Yes, with current Matter firmware | Not currently exposed |
| RGB indicator exposed as a separate light | Yes | Yes |
| RGB brightness / color control | Yes | Yes |
| Color temperature | Platform/device presentation may vary | Yes |
| Child-lock setting exposed in SmartThings | Not a standard Matter plug control | Yes |
| Charging-protection setting exposed in SmartThings | Not a standard Matter plug control | Yes |
| Configurable overload limit | Aqara documents this as Zigbee-only | Yes |
| Reverse / flip indicator behavior | Aqara documents this as Zigbee-only | Yes |
| RGB visualization of live power | No | Yes |
| RGB visualization of daily energy | No | Yes |
| RGB visualization of monthly energy | No | Yes |
| Configurable RGB power/energy gradient limits | No | Yes |
| Matter Multi-Admin / cross-platform sharing | Yes | No, not for a directly paired Zigbee device |
| Aqara accidental-removal protection | No | Device supports it in Zigbee mode; not implemented in this driver yet |
For users who primarily want standardized interoperability and Multi-Admin, Matter is an entirely reasonable choice. The main reason for using this Zigbee driver is access to the richer Aqara-specific feature set and direct control over how those functions are represented in SmartThings.
Aqara officially supports Zigbee mode with Aqara hubs. Direct Zigbee pairing to SmartThings using this community Edge driver is therefore not an Aqara-supported configuration.
The RGB indicator
The RGB ring is more than a conventional status LED. It can be controlled as a light, with on/off state, brightness, color and color temperature, but it can also visualize the plug’s own energy data.
The available indicator modes are:
- Fixed color
- Current power consumption
- Daily energy consumption
- Monthly energy consumption
In the consumption modes, the plug maps the measured value onto a color gradient. The upper end of that gradient can be configured separately for instantaneous power and accumulated energy.
This allows the indicator to show, for example, whether a connected appliance is drawing little or a lot of power without opening the SmartThings app. In fixed-color mode, it can instead be used as a general SmartThings status light for routines, alerts or reminders.
Driver features
The Edge driver represents the plug as two logical SmartThings components so that the electrical outlet and RGB indicator can be used independently.
Main component
The main component represents the actual socket and provides:
- On/off control
- Real-time power measurement
- Accumulated energy consumption
- Current measurement
- Refresh
LED component
The separate LED component represents the RGB indicator and provides:
- On/off control
- Brightness
- RGB color
- Color temperature
This arrangement makes the device useful in routines without tying the indicator to the electrical state of the socket. A washing machine can remain powered, for example, while the RGB ring turns green when a cycle has completed, or the indicator can show an unrelated SmartThings status without changing the connected appliance.
Driver settings
The following Aqara-specific settings are currently available directly in the SmartThings device settings.
Child lock
Disables normal operation of the physical button while remote control through SmartThings and routines remains available.
The physical button can still be used for network or factory reset. Aqara provides a stronger accidental-removal protection in Zigbee mode, but that function is not yet exposed by this driver because its Zigbee attribute mapping has not been verified.
Charging protection
When enabled, the plug automatically switches off after the connected load remains below approximately 3 W for 30 minutes.
Unlike the older Aqara H2 wall outlet, the SP-P05D does not appear to expose an adjustable low-power charging threshold; the 3 W / 30 minute behavior is defined by the device.
Power-on behavior
Controls the outlet state after mains power has been interrupted and restored.
Available options are:
- On
- Off
- Previous state
- Inverted/opposite state
Overload protection
Sets the maximum permitted load before the plug’s protection logic switches the outlet off.
The driver deliberately limits the SmartThings setting to 3680 W, matching the rated maximum resistive load of the EU product.
Flip indicator behavior
Reverses the normal relationship between the socket state and indicator behavior.
RGB indicator mode
Selects whether the RGB ring uses a fixed color or represents energy consumption:
- Fixed color
- Energy consumption per day
- Energy consumption per month
RGB power scale maximum
Defines the upper end of the RGB gradient when the indicator represents instantaneous power.
For example, with a value of 2000 W, the complete color range corresponds approximately to 0–2000 W.
RGB energy scale maximum
Defines the equivalent upper value for the daily or monthly accumulated-energy visualization.
Example SmartThings routines
Because the plug combines metering and a separately controllable RGB indicator, several useful routines can be implemented with a single physical device.
Washing machine finished
A routine can monitor the live power value and, once consumption remains below a chosen threshold for several minutes, send a notification and set the RGB indicator to green. The appliance remains connected while the indicator provides an immediate visual confirmation.
High-load warning
If the measured power rises above a selected value, SmartThings can turn the RGB indicator red while leaving the socket itself on. This provides a visible warning before the configured hardware overload threshold is reached.
Standby shutdown
For televisions, computers, chargers or other appliances with recognizable standby consumption, a routine can turn the socket off after power remains below a specified level for a chosen period.
General status indicator
The RGB component does not have to represent the plug at all. It can be used to indicate SmartThings Home Monitor state, an open door, an alarm condition or any other routine state while leaving the socket untouched.
Installation
The driver is available through my SmartThings Edge Driver channel:
SmartThings Edge Driver channel invitation
- Open the channel invitation and sign in with the Samsung account associated with the SmartThings location.
- Enroll the SmartThings Hub that should receive the driver.
- Open Available Drivers and install Aqara H2 Power Plug EU RGB.
- Make sure the SP-P05D is already operating in Zigbee mode.
- Start Zigbee pairing mode. A rapidly flashing purple indicator means Zigbee pairing; blue indicates Thread/Matter mode.
- In the SmartThings app, select Add device and start a nearby-device scan.
- With the driver installed before pairing, a production SP-P05D identifying as
lumi.plug.aeu005should be matched automatically.
The H2 family ships in Thread/Matter mode on first setup. Aqara’s documented protocol-switching process is performed during setup in the Aqara Home app. The exact Aqara-side workflow can depend on the app and hub combination, but for direct SmartThings Zigbee pairing the important point is that the plug must already be in Zigbee mode and flashing purple before SmartThings scans for it.
For reference, the documented button operations include:
- Double press, then hold for approximately 5 seconds: reset and enter pairing mode
- 10 consecutive presses: factory reset and enter pairing mode
- Purple rapid flashing: Zigbee pairing
- Blue rapid flashing: Thread/Matter pairing
- Single press: toggle the relay
- Triple press: identify / locate the device
If the plug has previously been paired through Matter or with another Zigbee driver, a clean reset and re-pair is recommended.
Current status
Hardware validation with a production SP-P05D is in progress.
The first release is intentionally conservative. Features are included only where there is sufficiently strong evidence for their Zigbee implementation; voltage and internal device temperature, for example, are not exposed merely because related Aqara devices support them.
The initial hardware tests are intended to confirm:
- automatic
lumi.plug.aeu005fingerprint matching - socket relay control
- live power, energy and current values
- manufacturer-specific settings
- RGB on/off, brightness, color and color-temperature behavior
- RGB energy-visualization modes
- complete isolation between RGB commands and the mains relay
This section will be updated with confirmed test results once hardware validation is complete.
Technical details
Click here
The SP-P05D is considerably more unusual internally than its appearance suggests. The main reason a dedicated driver is useful is that the electrical outlet and RGB indicator are logically separate devices even though the relevant Zigbee functions share the same physical endpoint.
Device identity
Current production firmware information identifies the RGB model as:
Manufacturer: Aqara / LUMI
Model: lumi.plug.aeu005
Retail model: SP-P05D
Manufacturer code: 0x115F
The non-RGB SP-P05E is listed separately as lumi.plug.aeu004.
Some early information identified an RGB H2 EU as lumi.plug.aeu004. A pre-production Zigbee interview appears to be the source of that conflict. Current firmware records distinguish the production devices clearly, so this driver fingerprints only:
Aqara / lumi.plug.aeu005
LUMI / lumi.plug.aeu005
Adding aeu004 would risk claiming production non-RGB plugs.
Endpoint and cluster architecture
Current implementation evidence places the main functions on endpoint 1.
Relevant clusters include:
| Cluster | Function |
0x0006 |
On/Off |
0x0300 |
Color Control |
0x0B04 |
Electrical Measurement |
0xFCC0 |
Aqara manufacturer-specific |
The unusual part is that the mains relay and RGB indicator share endpoint 1.
Normal Zigbee lighting logic often assumes that On/Off, Level Control and Color Control belong to the same logical light. That assumption is unsafe on the SP-P05D because the standard 0x0006 On/Off cluster controls the electrical outlet.
For example, a normal light implementation may use MoveToLevelWithOnOff, where setting brightness to zero can generate an implicit Off operation. On this plug that behavior can affect the mains relay.
The Edge driver therefore applies a strict separation:
main.switch
-> endpoint 1 / OnOff 0x0006
-> mains relay
led.switch
-> endpoint 1 / Aqara 0xFCC0 attribute 0x0203
-> RGB indicator
led.switchLevel
-> MoveToLevel
-> never MoveToLevelWithOnOff
led.colorControl
-> Color Control / CIE XY
led.colorTemperature
-> Color Control / color temperature
The LED handlers do not invoke SmartThings’ generic Zigbee switch defaults, and an unknown component command is never allowed to fall through to the mains relay.
This relay/LED collision is also handled explicitly by the recent Zigbee2MQTT H2 RGB converter, which disables the normal level-with-OnOff behavior for the same reason.
Electrical measurements
Instantaneous active power is obtained through the standard Zigbee Electrical Measurement cluster:
Cluster: 0x0B04
Attribute: ActivePower / 0x050B
Current H2 RGB implementation evidence indicates that ActivePower is reported directly in whole watts. The driver therefore uses a 1:1 multiplier/divisor rather than importing the /10 scaling used by some older Aqara plug implementations.
Energy and current are supplied through Aqara’s manufacturer-specific aggregate report:
Cluster: 0xFCC0
Attribute: 0x00F7
The relevant Aqara TLV tags are:
| Tag | Meaning | Driver interpretation |
0x95 |
Accumulated energy | kWh |
0x97 |
Current | mA converted to A |
0x98 |
Power | Secondary/fallback power value |
0x96 |
Voltage on some Aqara devices | Not currently observed/exposed for this model |
The driver uses 0x0B04 ActivePower as the primary power source and treats tag 0x98 as a fallback. A general Aqara TLV decoder is used instead of relying on fixed byte offsets, so aggregate packets remain parseable when tags are omitted, reordered or supplemented.
The current Zigbee implementation does not expose voltage or internal device temperature in SmartThings. The recent H2 RGB Zigbee2MQTT implementation likewise removes voltage and device-temperature exposes for this device.
The driver also avoids depending on Endpoint 21, Analog Input or Simple Metering. Those appeared in an early pre-production interview, while the current aeu005 implementation obtains live power from Electrical Measurement and energy/current from the Aqara aggregate.
Aqara manufacturer-specific attributes
The advanced settings are carried through Aqara’s manufacturer-specific cluster:
Cluster: 0xFCC0
The driver currently implements:
| Attribute | Type | Function |
0x00F0 |
UInt8 | Flip / reverse indicator behavior |
0x0202 |
Boolean | Charging protection |
0x0203 |
Boolean | RGB indicator on/off |
0x020B |
Float | Overload threshold |
0x0285 |
UInt8 | Child lock |
0x02DF |
UInt8 | RGB indicator mode |
0x02E0 |
Float | RGB power-gradient maximum |
0x02E1 |
Float | RGB energy-gradient maximum |
0x0517 |
UInt8 | Power-on behavior |
0x00F7 |
Aggregate | Measurement data |
The RGB indicator-mode mapping is:
| Value | Mode |
0 |
Fixed color |
1 |
Current power consumption |
2 |
Energy consumption per day |
3 |
Energy consumption per month |
Several settings use IEEE-754 single-precision floating-point values instead of ordinary integer Zigbee attributes. The driver therefore includes explicit Aqara manufacturer-specific read/write helpers and float handling.
Settings are not overwritten automatically when the device joins SmartThings. The existing physical configuration is read first, and manufacturer-specific writes are performed only after the corresponding SmartThings preference is changed. Writes are followed by readback verification.
RGB color implementation
The H2 RGB Zigbee implementation uses CIE XY color.
SmartThings normally represents color as hue and saturation, so the driver converts between the two representations:
SmartThings HSV
-> CIE XY
-> Zigbee Color Control
Incoming reports are converted in the opposite direction:
Zigbee CurrentX / CurrentY
-> HSV
-> SmartThings colorControl
Rapidly arriving hue and saturation commands are briefly coalesced before the final XY command is transmitted. This prevents intermediate color changes caused by combining a new hue with the previous saturation value, or vice versa.
Color temperature is handled independently through the Zigbee Color Control cluster. The driver uses the reported physical color-temperature range where available and falls back to approximately 2700–6500 K.
Reporting and configuration
Automatic Zigbee configuration is deliberately conservative.
Some recent Aqara devices expose standard clusters while omitting attributes that generic integrations normally expect. The H2 RGB has been reported to return UNSUPPORTED_ATTRIBUTE for several normal Electrical Measurement multiplier/divisor attributes, and probing all of them can interrupt configuration in other Zigbee integrations.
The driver therefore configures reporting only for the standard values known to be useful:
- Outlet On/Off state
- Active power
Manufacturer-specific settings are handled through explicit reads, unsolicited reports and read-after-write verification rather than assuming that Configure Reporting will work reliably for every 0xFCC0 attribute.
Sources and related work
The implementation and this post are based on several independent sources. The most important references are:
Aqara — Power Plug H2 EU (RGB), official product page
Product features, dual-protocol operation, 16 A / 3680 W rating, charging protection, child lock, overload/overheat behavior, Zigbee-exclusive settings and RGB energy visualization.
Power Plug H2 EU (RGB): Smart Plug with RGB Lighting & Energy Monitoring -
Aqara — Power Plug H2 EU support / user manual
Pairing modes, button operations, Thread/Zigbee setup and product identification.
Power Plug H2 EU - Help Center
Manual mirror: https://dwn.alza.cz/manual/190812 -
Aqara Firmware Archive — model and firmware identities
Current distinction betweenlumi.plug.aeu004/ SP-P05E andlumi.plug.aeu005/ SP-P05D, plus their Matter identities.
Aqara-Firmware-Archive/REGIONS.md at main · absent42/Aqara-Firmware-Archive · GitHub -
Aqara Power Plug H2 Zigbee2MQTT external converter —
aeu005.mjs
Current reference implementation for the RGB EU model, including the relay/RGB endpoint collision, manufacturer-specific attributes, ActivePower path and Aqara aggregate metering.
Aqara-Power-Plug-H2/aeu005.mjs at main · absent42/Aqara-Power-Plug-H2 · GitHub -
Aqara Community — Power Plug H2 UK & EU RGB with Zigbee2MQTT and Home Assistant
Background and implementation notes for the H2 RGB converters. The author has tested the UK RGB model; the EU converter is derived from it and was initially published as untested.
Power Plug H2 UK & EU RGB with Zigbee2MQTT and Home Assistant - Aqara Products - Aqara Forum -
Zigbee2MQTT / zigbee-herdsman-converters — Aqara implementation
Reference for Aqara0x00F7aggregate/TLV decoding and known measurement tags.
GitHub - Koenkk/zigbee-herdsman-converters: Collection of device converters to be used with zigbee-herdsman · GitHub -
Matter Smart Home — Matter plugs with energy reporting
Independent current testing showing Matter energy support for the Power Plug H2 EU / EU RGB from firmware0.0.5.0, including SmartThings as an ecosystem capable of displaying Matter energy data.
These Matter Smart Plugs Report Energy Data | Practice | matter-smarthome -
SmartThings Edge — Matter Electrical Power Measurement
ElectricalPowerMeasurement -
SmartThings Edge — Matter Electrical Energy Measurement
ElectricalEnergyMeasurement -
SmartThings Edge — Zigbee Electrical Measurement
ElectricalMeasurement
The driver also reuses design principles and proven implementation ideas from previous Aqara SmartThings Edge work, especially the Aqara H2 Wall Outlet, Aqara H2 Wall Switch and Aqara LED Bulb T2 drivers. The H2 Wall Outlet provided the basis for manufacturer-specific reads/writes and Aqara aggregate parsing, while the T2 bulb provided the established CIE XY color-conversion approach.
Known limitations
- Hardware validation of the first SmartThings build is still in progress.
- The driver currently targets production
lumi.plug.aeu005only. - Voltage is intentionally not exposed in Zigbee mode because no reliable production
aeu005Zigbee source has been confirmed. - Internal device temperature is not exposed as a SmartThings capability.
- Aqara accidental-removal protection is not implemented until its Zigbee attribute mapping is verified.
- OTA firmware updating is not implemented by this community driver.
- Aqara does not officially support direct Zigbee pairing of this device to SmartThings; this is a community-created Edge integration.
Disclaimer
This is a community-created SmartThings Edge driver. It is not an official SmartThings or Aqara release and is not maintained, reviewed or supported by either company.
As with any smart plug controlling mains-powered equipment, automations should be tested carefully, particularly when controlling unattended loads or devices where an unexpected switch operation could have safety consequences.
