Testers wanted for the US models!
Zigbee Edge Driver for lumi.switch.agl009, lumi.switch.agl010, lumi.switch.agl004 and lumi.switch.agl005
This driver targets the Zigbee mode of the Aqara H2 wall switches and is designed for SmartThings Edge.
Supported Zigbee model fingerprints:
Aqara / lumi.switch.agl009
Aqara H2 EU single channel / two-button wall switch
Retail model commonly documented as WS-K07EAqara / lumi.switch.agl010
Aqara H2 EU two channel / four-button wall switch
Retail models commonly documented as WS-K08E and WS-K08DAqara / lumi.switch.agl004
Aqara H2 US single channel / two-button wall switch
Retail model commonly documented as WS-K02EAqara / lumi.switch.agl005
Aqara H2 US two channel / two-button wall switch
Retail model commonly documented as WS-K03E
Why this driver exists
The Aqara H2 family is a dual-protocol product line. Aqara documents the switch as supporting Thread / Matter and Zigbee, but the richer Aqara-specific feature set is exposed on the Zigbee side. Aqara’s own product documentation highlights the dual-protocol design and public Zigbee integrations such as Zigbee2MQTT and ZHA expose the vendor-specific features that are not typically surfaced by generic Matter switch support.
That matters for SmartThings:
- Matter / Thread is excellent for generic cross-platform switch support.
- Zigbee is where the Aqara-specific features become visible:
- decoupled / wireless switch mode
- LED indicator control
- flipped LED logic
- relay lock
- power-on behavior
- multi-click enablement for the lower buttons
- richer button event handling
In other words: if you want the switch to behave like a generic Matter switch, Matter is fine. If you want the Aqara-specific bells and whistles, Zigbee is the interesting path.
Matter vs Zigbee: practical comparison
| Area | Matter / Thread path | Zigbee path |
| SmartThings onboarding | Excellent for generic switch support | Requires using the switch in Zigbee mode |
| Standard switch control | Yes | Yes |
| Separate relay tiles | Yes, via the SmartThings Matter switch driver | Yes, via this Zigbee driver’s child devices |
| Aqara-specific LED settings | Not typically exposed | Yes, via Aqara manufacturer cluster |
| Decoupled / wireless switch mode | Not typically exposed | Yes |
| Relay lock | Not typically exposed | Yes |
| Power-on behavior | Not typically exposed | Yes |
| Multi-click enablement | Not typically exposed | Yes |
| Rich button behavior | Limited by generic Matter modeling | Richer and better documented in Zigbee integrations |
| Best choice for this driver | Good baseline | Best choice for full feature access |
Important note about wiring
Aqara documents that the H2 supports both neutral and no-neutral wiring, but also states that power monitoring/reporting is tied to with-neutral setups. So real-time power and energy features depend on the actual installation.
Supported devices
Aqara H2 EU 1CH
- Zigbee model:
lumi.switch.agl009 - Common retail name: WS-K07E
- Layout:
- 1 relay
- 2 button surfaces
SmartThings layout in this driver:
- Parent:
mainaggregate button componentupbutton componentdownbutton componentpowerMeterenergyMeter
- Child devices:
relay1
Aqara H2 EU 2CH
- Zigbee model:
lumi.switch.agl010 - Common retail names: WS-K08E, WS-K08D
- Layout:
- 2 relays
- 4 button surfaces
- Parent:
mainaggregate button componentleftrightleftDownrightDownpowerMeterenergyMeter
- Child devices:
relay1= left relayrelay2= right relay
Aqara H2 US 1CH
- Zigbee model:
lumi.switch.agl004 - Common retail name: WS-K02E
- Layout:
- 1 relay
- 2 button surfaces
- Parent:
mainaggregate button componenttopbottompowerMeterenergyMeter
- Child devices:
relay1
Aqara H2 US 2CH
- Zigbee model:
lumi.switch.agl005 - Common retail name: WS-K03E
- Layout:
- 2 relays
- 2 button surfaces
- Parent:
- Child devices:
relay1= top relayrelay2= bottom relay
Preferences
The driver exposes Aqara-specific settings as SmartThings preferences.
Shared preferences
- LED indicator
- Flip LED
- Power-on mode
agl009
- Up mode
relaydecoupled
- Lock up relay
- Down multi-click
agl010
- Left mode
relaydecoupled
- Right mode
relaydecoupled
- Lock left relay
- Lock right relay
- Left-down multi-click
- Right-down multi-click
agl004
- Top mode
relaydecoupled
- Lock top relay
- Bottom multi-click
agl005
- Top mode
relaydecoupled
- Bottom mode
relaydecoupled
- Lock top relay
- Lock bottom relay
These preferences are not random UI extras; they map directly to Aqara attributes in 0xFCC0.
Installation
1. Driver Installation
- Open the driver channel invitation link.
- Sign in with your Samsung account.
- Accept the invitation.
- Enroll the SmartThings Hub that should receive the driver.
- Under Available Drivers, install the Aqara H2 Wall Switches (EU/US - 1CH/2CH) driver onto the enrolled hub.
1. Put the switch into Zigbee mode
This driver is for the Zigbee mode of the H2, not the Matter / Thread mode.
Aqara documents that the H2 is a dual-protocol device. If the switch is still operating in Matter / Thread mode, SmartThings will not use this Zigbee driver. If the switch was previously added in Matter mode, remove that Matter device first and then re-add it in Zigbee mode. Pair the Aqara H2 Wall Switches, or reassign / re-pair it if it is already paired with another driver.
2. Confirm the result in the app
After pairing:
- the parent device should appear as the button / settings / metering device
- one or two child relay devices should appear for the real relay outputs
If you only see one generic device, the switch is usually still in the wrong protocol mode or the driver is not installed on the hub that performed pairing.
Why this driver uses child devices
This Zigbee driver intentionally uses a parent + child device layout:
- Parent device
- buttons
- aggregate power / energy
- Aqara-specific preferences
- Child devices
- one child per real relay / load output
This was chosen for two reasons.
SmartThings officially supports this model
SmartThings documents Zigbee parent/child devices explicitly. A parent device can create EDGE_CHILD devices, assign them a parent_assigned_child_key, and manage endpoint-owned functionality through the parent device object.
The official SmartThings Matter switch driver already uses a very similar idea
The SmartThings Matter Switch driver creates child devices for additional switch endpoints. That is a very elegant representation because each relay gets its own clean SmartThings switch tile instead of forcing everything into one giant multi-component device.
For the Aqara H2 family that split feels natural:
- buttons belong together on the parent
- physical relays are better represented as separate child switches
This keeps the Zigbee driver conceptually aligned with the SmartThings Matter experience.
Driver architecture overview
Parent device responsibilities
The parent device is the “brains” of the SmartThings representation:
- button events
- aggregate power
- aggregate energy
- refresh
- Aqara-specific preferences and read/write logic
- Zigbee reporting setup
Child device responsibilities
Each child device represents one real relay endpoint:
switchrefreshhealthCheck
This is cleaner than a giant multi-component relay device and mirrors the way the official SmartThings Matter switch driver models multi-endpoint switches.
Endpoint map
lumi.switch.agl009
This is the 1-channel model.
Endpoint 1
- main relay
- upper / primary button events
- Aqara configuration attributes
- metering / electrical measurement base clusters
Endpoint 4
- secondary / lower button events
- Aqara
multi_clickattribute
Endpoint 21
- special power reporting endpoint
- public ZHA support maps this endpoint to a dedicated power-measurement handling path
lumi.switch.agl010
This is the 2-channel model.
Endpoint 1
- left relay
- left upper button events
- shared Aqara settings
Endpoint 2
- right relay
- right upper button events
- per-channel Aqara settings
Endpoint 4
- left-down button events
multi_click_left
Endpoint 5
- right-down button events
multi_click_right
Endpoint 21
lumi.switch.agl004
This is the US 1-channel model.
Endpoint 1
- main relay
- top button events
Endpoint 4
- bottom button events
- Aqara
Endpoint 21
lumi.switch.agl005
This is the US 2-channel model.
Endpoint 1
- top relay
- top button events
Endpoint 2
- bottom relay
Endpoint 21
Zigbee clusters used by the driver
Standard clusters
0x0006 On/Off
Used for the actual relay state and relay commands.
0x0012 Multistate Input
Used for button action events. This cluster is especially important on the H2 because button actions are not just simple on/off presses.
0x000C Analog Input
Used on endpoint 21 for power reporting.
0x0702 Simple Metering
Used for accumulated energy (kWh).
0x0B04 Electrical Measurement
Used as a supplementary path for instantaneous power and scaling values.
Other standard clusters seen on the device
Depending on model and endpoint, public integrations also show the usual clusters such as:
0x0000Basic0x0003Identify0x0004Groups0x0005Scenes0x000ATime0x0019OTA
The Aqara manufacturer-specific cluster
The most important part of the Zigbee implementation is Aqara’s custom manufacturer-specific cluster:
- Cluster ID:
0xFCC0 - Manufacturer code:
0x115F
This is where the interesting H2-specific settings live.
Known Aqara H2 attributes in 0xFCC0
| Attribute | ID | Meaning | Type / notes |
power_on_mode |
0x0517 |
startup behavior after power restore | uint8 enum |
operation_mode |
0x0200 |
relay mode vs decoupled mode | uint8 enum |
led_indicator |
0x0203 |
LED enable / disable | bool |
flip_led_indicator |
0x00F0 |
reverse indicator logic | bool carried as uint8 in ZHA |
lock_relay |
0x0285 |
relay lock | bool carried as uint8 in ZHA |
multi_click |
0x0286 |
enables multi-click actions | uint8; ZHA maps off=1, on=2 |
Value mapping used by public integrations
operation_mode
0x00= decoupled0x01= relay / control relay
power_on_mode
0x00= on0x01= previous0x02= off0x03= inverted
multi_click
Public ZHA support does not treat this as a plain 0/1 boolean. It maps:
1= off2= on
That is an easy detail to miss and one of the reasons a dedicated driver is useful.
Features exposed by the driver
Relay control
- separate SmartThings child device for each relay
- standard
switchcapability for each child
Buttons
agl009
- aggregate
main updown
agl010
- aggregate
main leftrightleftDownrightDown
agl004
- aggregate
main topbottom
agl005
- aggregate
main topbottom
Button behavior currently modeled in SmartThings
Based on current testing and the current driver model:
- EU upper buttons advertise
pushed - EU lower buttons advertise
pushed,doubleandheld - WS-K02E top button advertises
pushed - WS-K02E bottom button advertises
pushedanddouble - WS-K03E top and bottom buttons advertise
pushed - main acts as an aggregate button surface
This matches the practical observation that the lower buttons are the ones with explicit multi_click preferences and reliably exposed extra button actions, while the upper buttons behave more like standard relay-backed buttons.
Power and energy
The H2 is a little unusual here.
Power
Public ZHA support shows a dedicated power-measurement path on endpoint 21, based on AnalogInput.PresentValue, and configures reporting there.
This driver follows that idea and treats endpoint 21 as the preferred instantaneous-power path.
Energy
Accumulated energy comes from Simple Metering on the main relay endpoint.
Caveat
Aqara’s own product documentation says with-neutral wiring enables power monitoring and reports. So if the switch is wired without neutral, metering behavior may be limited or unavailable.
What public Zigbee integrations expose
Zigbee2MQTT
For WS-K07E, WS-K08E, WS-K02E and WS-K03E, Zigbee2MQTT documents exposure of items such as:
- power
- current
- energy
- LED indicator
- flipped indicator
- switch state
- device temperature
- power outage count
- power-on behavior
- operation mode
- relay lock
- multi-click
- action events
ZHA
The public ZHA quirk work for the H2 defines:
- a custom Aqara manufacturer cluster for H2 features
- endpoint 21 power measurement handling
- per-endpoint operation mode, lock relay, and multi-click settings
- button automation triggers including single, double, hold, and release in the quirk mapping
That ZHA work is one of the strongest public references for understanding the H2’s Zigbee behavior.
Current driver scope
This driver is focused on the core SmartThings experience that is both useful and maintainable.
Implemented / intended core scope
- child relay switches
- button events
- LED indicator preference
- flipped LED preference
- power-on behavior preference
- decoupled mode preference
- relay lock preference
- multi-click preference
- power meter
- energy meter
Documented by public integrations, but not necessarily exposed yet
Depending on the exact build revision, the following capabilities may still be future work rather than guaranteed SmartThings features:
currentMeasurement- device temperature
- release button events
The README lists them because they are relevant to the device and documented in Zigbee2MQTT / ZHA, but they should not be confused with a promise that every one of them is already exposed in the SmartThings UI.
Why not just use a single giant multi-component device?
That would work technically, but it is less elegant.
Using child devices gives you:
- one switch tile per relay
- clearer automations
- a structure that feels more like the official SmartThings Matter switch handling
- a clean separation between relay outputs and button surfaces
For a device like the H2, that is a very natural representation.
Known design trade-offs
- The device is dual-protocol, but this driver intentionally focuses on Zigbee mode because that is where the device-specific Aqara feature surface is visible.
- Public Zigbee integrations document more features than a conservative SmartThings driver should necessarily expose on day one.
- Power / energy behavior may depend on neutral wiring.
- If child devices are deleted manually, SmartThings parent/child models often require re-creation during onboarding or driver-managed reconciliation.
Sources
Official Aqara
- Aqara Light Switch H2 EU product page
Aqara Light Switch H2 – Dual Connectivity Smart Switch for Aqara Home & Apple Home Integration – Aqara LLC - Aqara Light Switch H2 EU specs page
Light Switch H2 EU – Aqara LLC - Aqara support page for the Light Switch H2 EU
Light Switch H2 EU – Help Center - Aqara Light Switch H2 US specs page
Light Switch H2 US-Specs - Aqara
Public Zigbee references
- Zigbee2MQTT: Aqara WS-K07E
Aqara WS-K07E control via MQTT | Zigbee2MQTT - Zigbee2MQTT: Aqara WS-K08E
Aqara WS-K08E control via MQTT | Zigbee2MQTT - Zigbee2MQTT: Aqara WS-K02E
Aqara WS-K02E control via MQTT | Zigbee2MQTT - Zigbee2MQTT: Aqara WS-K03E
Aqara WS-K03E control via MQTT | Zigbee2MQTT - ZHA PR: Added support for Aqara H2 switches (EU)
Added Support for Aqara H2 switches (EU+US) by lonevvolf · Pull Request #4141 · zigpy/zha-device-handlers · GitHub - ZHA PR: Added support for Aqara H2 switches (US)
Add Aqara light switch H2 US quirk by jerry0317 · Pull Request #4008 · zigpy/zha-device-handlers · GitHub
