AEG and Electrolux appliances are not in the SmartThings partner list. This gets an AEG / Electrolux tumble dryer (and washer dryer) into SmartThings with the official Electrolux Group Developer API.
What you get
Dryer state (run, pause, stop), job state (drying, cooling, wrinkle prevent, finished) and completion time
Door open/closed and remote control status
Start, pause and stop (when remote control is on)
Routine example: Dryer job state is Finished > send a notification
How it works
The Electrolux API is cloud only and Edge drivers can not reach the internet. So a small Python bridge on a pc that is always on (Windows or Docker) keeps a live event stream to Electrolux, and the Edge driver on the hub reads the bridge over your LAN.
Before you start
A pc that is always on with a fixed IP: Windows (installer included, network set to Private) or any Docker host (Linux, NAS, Raspberry Pi)
Log in at developer.electrolux.one with your AEG / Electrolux app account (email and password), create an API key and generate a token
Paste API key, access token and refresh token on the setup page (http://localhost:8787/setup, only reachable on that pc). The bridge refreshes the tokens itself
Moving the bridge to another Windows pc: install-remote.bat installs it there over the LAN and SmartThings keeps the same devices (see the README).
Offline notification: SmartThings has no routine trigger for “device offline”, so the Stoeckie Bridge device has a Connection status (Connected or Offline). Make a routine: if Stoeckie Bridge > Connection is Offline, send a notification to members. Short drops are ignored, it only turns Offline after 2 minutes down. Each drop is shown afterwards as Last drop (time, duration, reason).
Update (bridge 2026-11-02a, driver 2026-11-02a): less noise in the history
The dryer sent a new “completion time” on every poll, also when it was idle, so the SmartThings history filled up with dryer entries. Now the end time is only sent while a program runs, rounded to whole minutes, and only again when it moves 2 minutes or more. Update the bridge and the driver updates itself from the channel.
I looked at the bridge the way an attacker would. Until now any device on the LAN, and even a web page opened in a browser at home (DNS rebinding), could send commands to the bridge. Fixed:
The LAN API refuses requests from web pages (Origin header), hostnames instead of an IP, and anything that is not JSON.
Pairing: press Koppelen on the bridge setup page and the hub pairs by itself within 5 minutes. From then on every request from the hub is signed (HMAC SHA512 over method, path, time and body) and every answer is signed back. Replays, changed or old requests are refused, and a device that pretends to be the bridge cannot fool the hub. The token never crosses the LAN again after pairing.
Until you pair, everything keeps working as before; the setup page warns about it.
install-remote.bat now runs the bridge as LOCAL SERVICE (no admin rights), allows PowerShell remoting only from the managing pc, and installs Python packages with exact versions and hashes.
Update: copy the new files and run update-remote.bat (or install.bat / Docker), the driver updates itself from the channel, then press Koppelen. Details in the README.
If you made the Offline routine (Stoeckie Bridge (AEG dryer) device, Connection is Offline, send notification), duplicate it in the app and change the condition to Connection is Connected, with a text like “Stoeckie Bridge (AEG dryer) is back online”. Then you know the problem is over without opening the app. The device also shows Last drop (when, how long, why).
Update (bridge 2026-11-06c): setup page in English, easier on Docker
The setup page is now fully in English.
Docker: open http://localhost:8787/setup in a normal browser on the Docker host. That now also works without host networking (port mapping, Docker Desktop, many NAS): the bridge sees it runs in a container and allows the Docker network gateway. From another computer: add its address to STBRIDGE_SETUP_ALLOW in docker-compose.yml and open https://(docker host ip):8443/setup. Details in the README, section 1b.
To update: Docker git pull then docker compose up -d --build in the bridge folder; Windows: copy the new files and run install.bat again (config.json stays).
The bridge now needs Python 3.13 or newer. Windows: run install.bat (or update) again; it installs Python 3.13 and rebuilds the bridge environment by itself, your config.json stays. Docker: pull and rebuild, the image is now python:3.13-slim
Nothing else changes for this integration; the driver updates on the hub by itself
Bridge update 2026-11-07a: the bridge now runs on Python 3.14. Python 3.13 still gets security fixes, but no longer as Windows installers, so a Windows bridge would stay on an old 3.13. Windows: run install.bat again (it installs 3.14 and rebuilds the environment). Docker: git pull, then docker compose up -d --build. Packages are pinned with hashes as before, and new versions are only taken once they are at least a week old. No change for the dryer.
Update for the AEG / Electrolux dryer: driver 2026-11-09d and bridge 2026-11-09d
Warning: the LAN API of the bridge is now closed until a SmartThings hub is paired. If your setup page already says “SmartThings hub paired”, nothing changes. If not: after updating, the devices stop updating until you open the setup page, press Pair, wait until your hub shows up with its IP address and press Allow (driver 2026-11-02b or newer).
Fixed: Only changed values go to the hub. The dryer’s state and end time no longer get stuck in the app because the hub dropped events.
Fixed (2026-11-09c): with the AEG dryer set up, a token refresh saved an old copy of config.json and could undo the hub pairing and settings saved later.
Bridge security fixes: pairing needs Allow on the setup page, no plain http fallback for the setup page.
Driver 2026-11-09h: routines on the AEG / Electrolux dryer devices no longer run again after a driver update or hub reboot (the first value after a start was sent as a forced event). Details in the bridge topic.
