That kind of makes sense that I can’t find the driver if the switches are not supported.
Hopefully, I can find some that do.
I have to reset my hub. Prior to that I was able to use 2other drivers that worked. MC something and (forgive me I’m going to butcher the name) Maricino or something that starts with an m which worked.
Those are still in my hub but not showing up when I try to switch drivers.
You don’t need to reset your hub to remove drivers. You can do it by going back to the link where you installed a driver and do the uninstall. You can also do it from the ST Advanced Web App or the ST CLI.
Which driver are you referring to? I don’t see your specific model in either Mariano’s driver or Phil’s driver. You could trying installing Mariano’s zigbee-switch-v6.5 and see if that works, but I don’t see anything that suggests that it would.
Phil is the only one that I’m aware of. And most developers don’t put the presentation definition in their driver repo, so it’s hard to tell if single/double tap is supported for Automations or not. You could ask Corey to add the fingerprint for your device to Phil’s driver and see if that works or not.
When I try to select your driver, it doesn’t come up. Just like Phill30, it doesn’t show. However, Mariano’s is the only driver that appears for a selection?
Is there something that is preventing it from identifying that my switch would work with this driver? Maybe some sort of description. I definitely don’t know anything about code, just offering ideas.
When you do a “Change Driver”, the hub will look for any driver that matches whatever signatures are available for the drivers themselves. Some have signature of type, some are by manufactuer/model. Phils/mine are using the latter, so it should show as long as the manufacturer matches “Jasco Products” and a model of “43080”.
The only reasons I can think of is, the driver isn’t actually installed on your hub, or the device isn’t paired correctly. Try removing the device, rescanning and putting your device into pairing mode again.
