ST and Ring Alarm integration question
I have a ST with the Hub v2 US and a Ring Alarm with the Base Station 1.33.0. I found out that there is a way to integrate it together with this. It works, kind of. When I examined the devices in the live logging (contact sensors, motion sensors) I found two problems.
  • First of all one every refresh the sensors are stuck contact sensors reporting as closed and motion sensors as No motion, even though in the ring I can see them open/closed as it should be.
  • Secondly the sensors do not respond to the events - only the refresh event from the Ring integration.
So my question is how can I hook up the Ring contact sensor to event in ST? Might be I need to use a different integration routine?
Your link didn’t work (it links to a person, not a thread) but I think you are referring to the following topic:
Ring Alarm released! (Integration project in post 13)
I suggest you ask your question in that thread, since that’s where most of the people using the integration can be found. :sunglasses:
