Is there a way to make a https request without verifying the SSL certificate? I don’t seem to find a verify=false option. If it is not that simple, what is the workaround to do it?
Hi, @schwark.
I already asked the team about this, once I get more info, I’ll come back
Following up, @schwark, the team mentioned you can try verify = "none"
Hi - question regarding this SSL option. I’m porting a Python app that uses “check_hostname=False”. Is this the same thing as verify=‘none’ in Lua or are they different options? If they are different, can I use {check_hostname=false} in an SSL context parameter in an Edge driver?
Hi, @TAustin
I already shared your question with the engineering team, as soon as we get more info, we’ll let you know.
@TAustin, following up, the engineering team mentioned verify=none
should help you in this case and provided this sample:
local ssl = require 'cosock.ssl'
local socket = require 'cosock.socket'
-- more code
local sock, err = socket.tcp()
-- check errors, more code
local ssl_sock, err = ssl.wrap(sock, { mode = "client", protocol = "any", verify = "none", options = "all" })
-- check error and proceed
Excellent. Thank-you!!!
