Here is the log for the LED strip on manual. It was blue before the manual trigger. It did the flashing and then turned back on white. Here is the logs (Sorry they are long as it flashes 15 times):
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:44 AM: debug description is read attr - raw: 79250303000A01000020F6, dni: 7925, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: f6
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:43 AM: debug description is read attr - raw: 792503030008010020F6, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0001, encoding: 20, value: f6
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:41 AM: debug color cluster updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:41 AM: debug description is catchall: 0104 0300 03 01 0040 00 7925 00 00 0000 0B 01 0300
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:41 AM: debug description is read attr - raw: 792503030008000020AA, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: aa
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:39 AM: debug description is read attr - raw: 792503030008000020D6, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: d6
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:39 AM: debug description is read attr - raw: 792503030008000020FD, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: fd
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:39 AM: debug color cluster updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:39 AM: debug description is catchall: 0104 0300 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: debug [raw:0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:7925, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00], clusterInt:8, commandInt:11]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: debug level updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: debug description is catchall: 0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:37 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:36 AM: trace setColor([hue:67, saturation:97, level:100])
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:36 AM: debug [name:level, value:100]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:36 AM: debug description is read attr - raw: 792503000808000020FE, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:34 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:34 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:34 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:34 AM: debug [name:level, value:100]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:34 AM: debug description is read attr - raw: 792503000808000020FE, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:32 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:32 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug [name:level, value:4]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug description is read attr - raw: 7925030008080000200A, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 0a
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:31 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:29 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:29 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug [name:level, value:30]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug description is read attr - raw: 7925030008080000204B, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 4b
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:28 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:26 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:26 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug [name:level, value:34]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug description is read attr - raw: 79250300080800002057, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 57
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:25 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:23 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:23 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug [name:level, value:33]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug description is read attr - raw: 79250300080800002054, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 54
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:22 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:20 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:20 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug [name:level, value:26]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug description is read attr - raw: 79250300080800002041, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 41
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:19 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:17 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:17 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug [name:level, value:31]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug description is read attr - raw: 79250300080800002050, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 50
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:16 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:13 AM: debug description is read attr - raw: 79250303000A01000020FE, dni: 7925, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: fe
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:12 AM: debug description is read attr - raw: 792503030008010020FE, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0001, encoding: 20, value: fe
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug description is read attr - raw: 792503030008010020F9, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0001, encoding: 20, value: f9
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug color cluster updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:10 AM: debug description is catchall: 0104 0300 03 01 0040 00 7925 00 00 0000 0B 01 0300
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:09 AM: debug description is read attr - raw: 792503030008000020FE, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: fe
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:08 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:08 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is read attr - raw: 792503030008000020AB, dni: 7925, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: ab
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug color cluster updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is catchall: 0104 0300 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug [name:level, value:22]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is read attr - raw: 79250300080800002038, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 38
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug [name:level, value:1]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is read attr - raw: 79250300080800002002, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 02
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is on/off: 1
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:07 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:06 AM: debug [name:switch, value:off]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:06 AM: debug description is on/off: 0
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:06 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0000
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:06 AM: debug [name:level, value:99]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:06 AM: debug description is read attr - raw: 792503000808000020FC, dni: 7925, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fc
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: debug [name:switch, value:on]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: debug description is catchall: 0104 0006 03 01 0040 00 7925 00 00 0000 0B 01 0100
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: debug [raw:0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:7925, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00], clusterInt:8, commandInt:11]
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: debug level updated successfully
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: debug description is catchall: 0104 0008 03 01 0040 00 7925 00 00 0000 0B 01 0400
79f6ef31-377c-4afb-9d90-27cd037be0b8 9:38:05 AM: trace setColor([hue:100, saturation:100, level:100])
