Neither 50001, 80, or 3335 seem to work. Connection refused on 50001 and 3335, a 404 error on port 80
Edit: This is with a Bravia X850C set.
Shoot I meant 33335. But not a good sign if 8080 is closed
That link dint work for me either. Here the other link I found on the web : https://raw.githubusercontent.com/breunigs/bravia-auth-and-remote/master/commands
The content at OpenRemote is the best starting point for information, but you need to be aware that there are several different generations of sets with slightly different web service APIs and most people arenât being particularly clear as to what set theyâre testing with. The IP API seems more consistent across models but thatâs not going to work without an external helper app which is a non-starter for me.
Hoping to see if we can get this working, I tried the link that @Kristopher asked us to try but it didnât work. Then I saw the post from @hcgonzalezpr and tried the same link with port 52323 and it worked but I got a blank page with a 404 for the file
I have a x850c as well. Maybe we can see if thereâs something we can do with Android? Doubtful ADB would be of use here but who knows lol.
Wading through the examples people posted on the OpenRemote page (and I know itâs confusing because itâs a hodgepodge of different things for different models), I was able to do all the basic things from curl and Postman, so I think the information is actually all there. I could get the x850c to pop up the remote app configuration screen with the code to use for getting the cookie and I was able to send a bunch of different commands. I think it would definitely be possible to create a nice driver for the current crop of 2015 Sony TVs (i.e. the Android-based X850c, X810c, X830c, X900c, etc.) but it does seem like if you try to create something general purpose that works across several years and models, youâve got a lot of edge cases to support.
Would you mind posting your CURL commands that worked for you? Iâd like to take them and create a device handler once my TV arrives this Friday.
Iâll go through them again this weekend and copy the ones that work into a Pastebin. It was just trial and error and I was mostly just seeing if it was possible. Half the stuff on the OpenRemote page isnât recognized and of the half that can be recognized, half of that wonât really work until you get the authentication flow done right and that part seems to be very different from model to model (although I suspect all the 2015 models are the same). Once youâve authed and are sending the right headers, then you can just start seeing which ones work and which donât.
Okay, sounds good. Looking forward to being able to put together something useful. Once Iâve got the TV and such I can also probe the API and see what you may have missed.
Thanks for doing a lot of the leg work on this.
The TV model I got its a pre-android W600b. I donât own a Android version one. I check one of the Android versions at best-buy and saw they provide serial access for enterprise control. There are multiple protocols on each generation of these TV. I have created a list so we can keep better track of it.
https://docs.google.com/spreadsheets/d/1kV5lYGAvMJVOYkomk_17Ng_XtK5y7KhGZzdG2X1yQD4/edit?usp=sharing
hi,
This thread is very interesting and i would love to get this to work!
Where would i find: HelperIP, HelperPort, HelperURL, TvIP?
I have managed to control the TV through simple rest client through following the link at http://www.openremote.org/pages/viewpage.action?pageId=22887143&focusedCommentId=23605578#comment-23605578
Any help would be appreciated.
Hi All,
Based on the link dthomp13 posted and the code from hcgonzalezpr I was finally able to get a smartthings SOAP call to work. Not sure if this will help any of you but I figured I would post it just in case. My TV ix an x850c. Before this can work be sure to set the TV for a Pre-Shared Key (details in the link from dthomp13 ).
Note to set up the x850c for a pre-shared key go to the following in the TV menus
Settings->Network->home network->IP Control->Authentication->Set to Normal and Pre-Shared Key
Settings->Network->home network->IP Control->Authentication->Pre-Shared Key-> Set to a Key to use for controls (in the example from the link above the key is 1111).
Finally the code that worked for me is:
//so this sends the correct SOAP code to the TV. The code below is a Wake On Lan code.
def on() {
def rawcmd = "AAAAAQAAAAEAAAAuAw==" //Wake On LAN
def ip = "192.168.1.202" //TV's IP
def port = "80" //TV's Port
setDeviceNetworkId(ip,port)
log.debug( "Device IP:Port = ${ip}:${port}" )
def sonycmd = new physicalgraph.device.HubSoapAction(
path: '/sony/IRCC',
urn: "urn:schemas-sony-com:service:IRCC:1",
action: "X_SendIRCC",
body: ["IRCCCode":rawcmd],
headers: [Host:"${ip}:${port}", 'X-Auth-PSK':"1111"] //pre shared key (make sure TV is set up for Pre-shared Key!
sendHubCommand(sonycmd)
log.debug( "hubAction = ${sonycmd}" )
log.debug "Executing 'on'"
Although I think this information has already been discussed, this blog post explains the code at the https://github.com/breunigs/bravia-auth-and-remote GitHub repo.
hi,
has anyone built a app yet for the code above?
thanks
Dale
I am wondering the exact same thing, I would love to have an app for this.
Iâm really interested in getting this working, but Iâm a bit stuck. Iâm new to the SmartThings platform, but have a fairly good technical understanding (I work in IT and have previously been a developer). I understand the principles involved, but at the moment I seem to have too many confounding factors to understand why I canâ make this work.
What Iâve done so far:
Created a Device Handler using the code from @CRubio above. Iâm not sure if this code is supposed be used in this way. I have the device configured as a switch with commands which send the On (rawcmd = âAAAAAQAAAAEAAAAuAw==â)/ Off (rawcmd = âAAAAAQAAAAEAAAAvAw==â) messages.
Enabled Simple IP control on my Sony X8309C (pre-shared key to 1111) and confirmed that itâs using port 5353 by looking at the network traffic from the Sony Remote app using Wireshark.
Questions:
Iâve added my code here:
So I had a lot of trouble with the simulator and getting the tiles to work easily in it (I gave up and started to use my phone instead). Ultimately I came up with the following (see below - momentary button copied from another thread not my own), but it was admittedly half assed. The more I looked at the code the more I realized that I would have to come up with a device handler for each control function (or function pairs like on/off). So I just decided to create momentary buttons in the device handlers. This way at least I could create something akin to the actual TV remote controlâŠbut I would have to create a device handler and then a device for each function. Not very extensible.
I finally ended up using the Alexa Helper app to help making control more extensible, but that app for now just does local IP control using the HubAction and not the HubSoapAction. Wish I could be more helpful but wanted to reply with something more than just dead airâŠ
Hopefully you can work through the issues you are seeingâŠ
* Momentary Button Tile
* Author: SmartThings
* Date: 2013-05-01
metadata {
// Automatically generated. Make future change here.
definition (name: "Bravia_On", namespace: "CRSounds", author: "Carlton Rubio") {
capability "Actuator"
capability "Switch"
capability "Momentary"
capability "Sensor"
// simulator metadata
simulator {
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "off", label: 'Push', action: "momentary.push", backgroundColor: "#ffffff", nextState: "on"
state "on", label: 'Push', action: "momentary.push", backgroundColor: "#53a7c0"
main "switch"
details "switch"
def push() {
sendEvent(name: "switch", value: "on", isStateChange: true, display: false)
sendEvent(name: "switch", value: "off", isStateChange: true, display: false)
sendEvent(name: "momentary", value: "pushed", isStateChange: true)
def port = "80"
path: '/sony/IRCC',
log.debug "Executing 'push'"
def on() {
push()
log.debug "Executing 'on push'"
def off() {
push()
log.debug "Executing 'off push'"
Itâs looking like it may make more sense to use the JSON-RPC API rather than the SOAP API. The reason is because if you want to create a single switch to turn on and off the TV, youâll need to use polling to get the TV power status, which is made through a getPowerStatus JSON-RPC call. I took a stab at creating a version of @jamieyates79âs example but using the JSON-RPC API and having it poll for the TV state. Hereâs the code: https://gist.github.com/edanuff/3d8656db80580fea16e2d409ac8f5ccb
Note: Itâs very important that the device network ID is set correctly or polling wonât work. The next step of making this work would be to create a SmartApp that properly sets up the device handler with the correct device network ID.
Edit: It may be possible to check on the state of the TV via subscribing to UPnP events which would be better than polling.
cool. this is working for me. Iâm going to look into UPnP as Iâd like to know when the TV status when it is manually turned on.
