Sonos Notify with Sound to multiple Sonos Devices
I made a quick change to the app you can use here. All I did was ad “multiple: True” to line 95.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Sonos Custom Message
 *  Author: SmartThings
 *  Date: 2014-1-29
definition(
	name: "Sonos Notify with Sound_Multiple",
	namespace: "smartthings",
	author: "SmartThings",
	description: "Play a sound or custom message through your Sonos when the mode changes or other events occur.",
	category: "SmartThings Labs",
	iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos.png",
	iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos@2x.png"
preferences {
	page(name: "mainPage", title: "Play a message on your Sonos when something happens", install: true, uninstall: true)
	page(name: "chooseTrack", title: "Select a song or station")
	page(name: "timeIntervalInput", title: "Only during a certain time") {
		section {
			input "starting", "time", title: "Starting", required: false
			input "ending", "time", title: "Ending", required: false
def mainPage() {
	dynamicPage(name: "mainPage") {
		def anythingSet = anythingSet()
		if (anythingSet) {
			section("Play message when"){
				ifSet "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
				ifSet "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
				ifSet "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
				ifSet "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
				ifSet "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
				ifSet "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
				ifSet "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
				ifSet "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
				ifSet "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
				ifSet "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
				ifSet "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
				ifSet "triggerModes", "mode", title: "System Changes Mode", required: false, multiple: true
				ifSet "timeOfDay", "time", title: "At a Scheduled Time", required: false
		def hideable = anythingSet || app.installationState == "COMPLETE"
		def sectionTitle = anythingSet ? "Select additional triggers" : "Play message when..."
		section(sectionTitle, hideable: hideable, hidden: true){
			ifUnset "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
			ifUnset "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
			ifUnset "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
			ifUnset "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
			ifUnset "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
			ifUnset "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
			ifUnset "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
			ifUnset "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
			ifUnset "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
			ifUnset "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
			ifUnset "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
			ifUnset "triggerModes", "mode", title: "System Changes Mode", description: "Select mode(s)", required: false, multiple: true
			ifUnset "timeOfDay", "time", title: "At a Scheduled Time", required: false
		section{
			input "actionType", "enum", title: "Action?", required: true, defaultValue: "Custom Message", options: [
				"Custom Message",
				"Bell 1",
				"Bell 2",
				"Dogs Barking",
				"Fire Alarm",
				"The mail has arrived",
				"A door opened",
				"There is motion",
				"Smartthings detected a flood",
				"Smartthings detected smoke",
				"Someone is arriving",
				"Piano",
				"Lightsaber"]
			input "message","text",title:"Play this message", required:false, multiple: false
		section {
			input "sonos", "capability.musicPlayer", title: "On this Sonos player", required: true, multiple: true
		section("More options", hideable: true, hidden: true) {
			input "resumePlaying", "bool", title: "Resume currently playing music after notification", required: false, defaultValue: true
			href "chooseTrack", title: "Or play this music or radio station", description: song ? state.selectedSong?.station : "Tap to set", state: song ? "complete" : "incomplete"
			input "volume", "number", title: "Temporarily change volume", description: "0-100%", required: false
			input "frequency", "decimal", title: "Minimum time between actions (defaults to every event)", description: "Minutes", required: false
			href "timeIntervalInput", title: "Only during a certain time", description: timeLabel ?: "Tap to set", state: timeLabel ? "complete" : "incomplete"
			input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
				options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
			if (settings.modes) {
            	input "modes", "mode", title: "Only when mode is", multiple: true, required: false
			input "oncePerDay", "bool", title: "Only once per day", required: false, defaultValue: false
		section([mobileOnly:true]) {
			label title: "Assign a name", required: false
			mode title: "Set for specific mode(s)", required: false
def chooseTrack() {
	dynamicPage(name: "chooseTrack") {
		section{
			input "song","enum",title:"Play this track", required:true, multiple: false, options: songOptions()
private songOptions() {
	// Make sure current selection is in the set
	def options = new LinkedHashSet()
	if (state.selectedSong?.station) {
		options << state.selectedSong.station
	else if (state.selectedSong?.description) {
		// TODO - Remove eventually? 'description' for backward compatibility
		options << state.selectedSong.description
	// Query for recent tracks
	def states = sonos.statesSince("trackData", new Date(0), [max:30])
	def dataMaps = states.collect{it.jsonValue}
	options.addAll(dataMaps.collect{it.station})
	log.trace "${options.size()} songs in list"
	options.take(20) as List
private saveSelectedSong() {
	try {
		def thisSong = song
		log.info "Looking for $thisSong"
		def songs = sonos.statesSince("trackData", new Date(0), [max:30]).collect{it.jsonValue}
		log.info "Searching ${songs.size()} records"
		def data = songs.find {s -> s.station == thisSong}
		log.info "Found ${data?.station}"
		if (data) {
			state.selectedSong = data
			log.debug "Selected song = $state.selectedSong"
		else if (song == state.selectedSong?.station) {
			log.debug "Selected existing entry '$song', which is no longer in the last 20 list"
		else {
			log.warn "Selected song '$song' not found"
	catch (Throwable t) {
		log.error t
private anythingSet() {
	for (name in ["motion","contact","contactClosed","acceleration","mySwitch","mySwitchOff","arrivalPresence","departurePresence","smoke","water","button1","timeOfDay","triggerModes","timeOfDay"]) {
		if (settings[name]) {
			return true
	return false
private ifUnset(Map options, String name, String capability) {
	if (!settings[name]) {
		input(options, name, capability)
private ifSet(Map options, String name, String capability) {
def installed() {
	log.debug "Installed with settings: ${settings}"
	subscribeToEvents()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	unschedule()
	subscribeToEvents()
def subscribeToEvents() {
	subscribe(app, appTouchHandler)
	subscribe(contact, "contact.open", eventHandler)
	subscribe(contactClosed, "contact.closed", eventHandler)
	subscribe(acceleration, "acceleration.active", eventHandler)
	subscribe(motion, "motion.active", eventHandler)
	subscribe(mySwitch, "switch.on", eventHandler)
	subscribe(mySwitchOff, "switch.off", eventHandler)
	subscribe(arrivalPresence, "presence.present", eventHandler)
	subscribe(departurePresence, "presence.not present", eventHandler)
	subscribe(smoke, "smoke.detected", eventHandler)
	subscribe(smoke, "smoke.tested", eventHandler)
	subscribe(smoke, "carbonMonoxide.detected", eventHandler)
	subscribe(water, "water.wet", eventHandler)
	subscribe(button1, "button.pushed", eventHandler)
	if (triggerModes) {
		subscribe(location, modeChangeHandler)
	if (timeOfDay) {
		schedule(timeOfDay, scheduledTimeHandler)
	if (song) {
		saveSelectedSong()
	loadText()
def eventHandler(evt) {
	log.trace "eventHandler($evt?.name: $evt?.value)"
	if (allOk) {
		log.trace "allOk"
		def lastTime = state[frequencyKey(evt)]
		if (oncePerDayOk(lastTime)) {
			if (frequency) {
				if (lastTime == null || now() - lastTime >= frequency * 60000) {
					takeAction(evt)
				else {
					log.debug "Not taking action because $frequency minutes have not elapsed since last action"
			else {
				takeAction(evt)
		else {
			log.debug "Not taking action because it was already taken today"
def modeChangeHandler(evt) {
	log.trace "modeChangeHandler $evt.name: $evt.value ($triggerModes)"
	if (evt.value in triggerModes) {
		eventHandler(evt)
def scheduledTimeHandler() {
	eventHandler(null)
def appTouchHandler(evt) {
	takeAction(evt)
private takeAction(evt) {
	log.trace "takeAction()"
	if (song) {
		sonos.playSoundAndTrack(state.sound.uri, state.sound.duration, state.selectedSong, volume)
	else if (resumePlaying){
		sonos.playTrackAndResume(state.sound.uri, state.sound.duration, volume)
	else {
		sonos.playTrackAndRestore(state.sound.uri, state.sound.duration, volume)
	if (frequency || oncePerDay) {
		state[frequencyKey(evt)] = now()
	log.trace "Exiting takeAction()"
private frequencyKey(evt) {
	"lastActionTimeStamp"
private dayString(Date date) {
	def df = new java.text.SimpleDateFormat("yyyy-MM-dd")
	if (location.timeZone) {
		df.setTimeZone(location.timeZone)
	else {
		df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
	df.format(date)
private oncePerDayOk(Long lastTime) {
	def result = true
	if (oncePerDay) {
		result = lastTime ? dayString(new Date()) != dayString(new Date(lastTime)) : true
		log.trace "oncePerDayOk = $result"
	result
// TODO - centralize somehow
private getAllOk() {
	modeOk && daysOk && timeOk
private getModeOk() {
	def result = !modes || modes.contains(location.mode)
	log.trace "modeOk = $result"
	result
private getDaysOk() {
	def result = true
	if (days) {
		def df = new java.text.SimpleDateFormat("EEEE")
		else {
		def day = df.format(new Date())
		result = days.contains(day)
	log.trace "daysOk = $result"
	result
private getTimeOk() {
	def result = true
	if (starting && ending) {
		def currTime = now()
		def start = timeToday(starting, location?.timeZone).time
		def stop = timeToday(ending, location?.timeZone).time
		result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
	log.trace "timeOk = $result"
	result
private hhmm(time, fmt = "h:mm a")
	def t = timeToday(time, location.timeZone)
	def f = new java.text.SimpleDateFormat(fmt)
	f.setTimeZone(location.timeZone ?: timeZone(time))
	f.format(t)
private getTimeLabel()
	(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
// TODO - End Centralize
private loadText() {
	switch ( actionType) {
		case "Bell 1":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", duration: "10"]
			break;
		case "Bell 2":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell2.mp3", duration: "10"]
			break;
		case "Dogs Barking":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/dogs.mp3", duration: "10"]
			break;
		case "Fire Alarm":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/alarm.mp3", duration: "17"]
			break;
		case "The mail has arrived":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/the+mail+has+arrived.mp3", duration: "1"]
			break;
		case "A door opened":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/a+door+opened.mp3", duration: "1"]
			break;
		case "There is motion":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/there+is+motion.mp3", duration: "1"]
			break;
		case "Smartthings detected a flood":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+a+flood.mp3", duration: "2"]
			break;
		case "Smartthings detected smoke":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+smoke.mp3", duration: "1"]
			break;
		case "Someone is arriving":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/someone+is+arriving.mp3", duration: "1"]
			break;
		case "Piano":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/piano2.mp3", duration: "10"]
			break;
		case "Lightsaber":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/lightsaber.mp3", duration: "10"]
			break;
		default:
			if (message) {
				state.sound = textToSpeech(message instanceof List ? message[0] : message) // not sure why this is (sometimes) needed)
			else {
				state.sound = textToSpeech("You selected the custom message option but did not enter a message in the $app.label Smart App")
			break;
