This looks very interesting for getting Sonos to play nice in ST. I am running an Unraid server and I am wondering if you know of Node servers for this platform? I see Node-red in the unraid dockers http://nodered.org/ and I am wondering if this would work the same way?
I am having a hard time getting this going. I did the npm install sonos and it seemed to do that and it put it into the node_modules directory. However in step 5 above, where am I supposed to run this command from? I am using windows so do I run it in the command screen? I have tried to do this but I am getting an error module.js:471 throw err. I think I am missing something.
I haven’t used a windows machine in AGES, so I’m just guessing here - but we’re you in the node-modules directory when you ran the node server.js command? If so, then all I can say is try Googling how to start a node server from Windows.
OK, I got this working. I am trying to test the Say command and I have created the settings.json file with my Voice RSS API as per the instructions from jishi’s site. It says to put this in the root directory. Which root directory? I put it in the sonos node directory but it just keeps saying that I have to have a registered API. Any ideas?
I don’t know anything about SmartThings, but you can definitely control Sonos with HTTP commands, and you can group speakers too (I discovered this yesterday). In my case, I have a Sonos Connect taking sound from line-in. I set the Sonos Connect URI to x-rincon-stream:xxx, and the Play:1s I set to x-rincon:xxx. This groups the Play:1s with the Connect.
Connect:
x-rincon-stream:RINCON_01400
Play 1s:
x-rincon:RINCON_01400
I attach a screenshot of the HTTP command from my - ahem - competing home automation controller.
