SONOFF ZBMINI keeps going offline
Ive tried both the stock edge driver and the Mariano Switch MC, but it will only stay online for a short while. Switching off and on will usually get it back online again, but i wanted to use it to trigger a house-alarm siren (and i can’t rely on it as is).
Any other driver suggestons, or ideas for alternative (more reliable) switches? It does not have to be Zigbee.
Hi,
Is that because it has not been configured correctly in the installation or could it be far from the hub?
If it is far away, try to insert a repeater
Uninstall it, put it in pairing mode and add it as close to the hub as you can.
Thanks. I will try a reinstall. It’s only a few metres from the hub, so i doubt the issues are due to the distance.
