Sonoff SNZB-02D Temperature on room tile
Hi.
I have the SNZB-02D integrated via ewelink, but on top of the room and on the tile only show the humidity, and on top on little tile should show the temperature and then humidity…
Its a problem by the ewelink integration? If i conect direct it work?
The temperature tile is only shown for certain categories of device. I suspect it might only be categorised as a humidity sensor rather than using the more recent TempHumiditySensor category.
I just send a ticket to ewelink and they will see that. Thanks
Direct integration on aeotec hub with Veon Drivers work very well like a thermostat
