paul42
(Paul Lamm)
February 23, 2020, 11:28pm
1
Flashed a basic with Tasmota 8. Set Gpio14 to switch one. Added wires to gnd and key solder pads
But when I touch the wires together the led flashes once and I take the wires apart then turns relay on. Touch again relay off. I want it to work as a toggle light switch not momentary.
Am i missing a setting in Tasmota?
GSzabados
(Gabor Szabados)
February 24, 2020, 5:45pm
2
FYI, this is the SmartThings Community forum and not the Tasmota one.
Otherwise the first result in Google for Tasmota switch settings
Alternative firmware for ESP8266 with easy configuration using webUI, OTA updates, automation using timers or rules, expandability and entirely local control over MQTT, HTTP, Serial or KNX - arends...
