Hi community,
I’m creating a new device type and something goes wrong, my device is a ZigBee falls sensor. I don´t know if it is well implemented but for now in the part of “Tiles” something must be wrong because the icon which appear is unknown and doesn´t change color when i simulte from active to inactive . What else is good?
* Detector de caidas
* Copyright 2015 Adrián López Delgado
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (
name: "Detector de caidas",
namespace: "Adrián TFG",
author: "Adrián López Delgado") {
capability "sensor"
fingerprint inClusters: "0000, 0003, 00b2",
endpointId: "08",
profileId: "0104"
command 'active'
command 'inactive'
simulator {
// status messages
status "active": "active/inactive: 1"
status "inactive": "active/inactive: 0"
// reply messages
reply "zcl on-off active":"active/inactive: 1"
reply "zcl on-off inactive":"active/inactive: 0"
tiles {
standardTile("sensor", "device.sensor", width: 2, height: 2, canChangeIcon: true) {
state "inactive", label: 'inactive', action: "sensor.on", icon: "st.categories.damageAndDanger", backgroundColor: "#e86d13"
state "active", label: 'active', action: "sensor.off", icon: "st.categories.damageAndDanger", backgroundColor: "#53a7c0"
main "sensor"
details(["sensor"])
// Parse incoming device messages to generate events
log.info description
if (description?.startsWith("catchall:")) {
def value = name == "sensor" ? (description?.endsWith(" 1") ? "active" : "inactive") : null
def result = createEvent(name:name, value:value)
def msg = zigbee.parse(description)
return result
} else{
def name = description?.startsWith("on/off: ") ? "sensor": null
return result
def result = createEvent(name: name, value: value)
return result
// handle commands
def active() {
log.debug "Execution 'active()'"
sendEvent(name: "sensor", value: "active")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}"
'zcl active/inactive active'
def off() {
log.debug "Execution 'inactive()'"
sendEvent(name: "sensor", value: "inactive")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}"
'zcl active/inactive inactive'
