First let me say that I have searched and read the same things and tried the same things ( at least to the best of my abilities).
removed EVERYTHING from my ST app (including webcore, rooms, phone, lights, hue hub, smart apps) empty.
Installed from scratch - renamed hub to remove the ip address
Reset the hub
Re Installed (God knows how many times)
in the end the logs show the same thing every time
d3ada23f-7571-4f07-9760-e399a9b417e9 9:10:16 AM: error java.lang.ArrayIndexOutOfBoundsException: 1
d3ada23f-7571-4f07-9760-e399a9b417e9 9:10:16 AM: trace Bridge discovering all items on Hue hub.
d3ada23f-7571-4f07-9760-e399a9b417e9 9:09:56 AM: error java.lang.ArrayIndexOutOfBoundsException: 1
d3ada23f-7571-4f07-9760-e399a9b417e9 9:09:56 AM: trace Bridge discovering all items on Hue hub.
a5a886b8-eee1-4b0e-ac2d-732b5bfcd5a7 9:09:53 AM: debug Previously found bridge discovered
a5a886b8-eee1-4b0e-ac2d-732b5bfcd5a7 9:09:53 AM: debug Discovered bridge 0017886B2AE1 (192.168.1.4)
a5a886b8-eee1-4b0e-ac2d-732b5bfcd5a7 9:09:53 AM: debug Discovery Response is [devicetype:04, mac:0017886B2AE1, networkAddress:C0A80104, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017886b2ae1, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:22cbce32-f86b-47f1-b935-80e7d2d7d32e].
a5a886b8-eee1-4b0e-ac2d-732b5bfcd5a7 9:09:52 AM: debug Previously found bridge discovered
Am at a loss any new suggestions?
I am fairly new to ST. In regards to Device Handlers (DH, DTH) I included the Bridge, Bulb, Group and Scene).
My system has about 20 white/color bulbs 4 light strips and 4 white ambiance bulbs. (I’ve even tried adding each DH to include ALL of them.
I am at a loss on what to do - hopefully someone can help with a bit of direction.
