Brand new Hub v3 setup and working on Wifi about 3 weeks ago. Accidentally deleted Hub in ST app (newb). Now I can’t get it back to Wifi…
Hub had to be added to ST app with Ethernet, because I could not get it working on wifi, no matter how many times I factory reset it. Now just trying to change to wifi, and it’s failing at the exact same place as trying to set it up with wifi initially:
-press reset button until light turns from solid GREEN to blinking YELLOW
-scan barcode with ST app
-ST app asks “device to use with SmartThings”
-choose my home wifi network
-phone says "network has been disconnected’
-app says “Verifying code”
-phone reconnects to my wifi, then disconnects again
-REPEAT Verifying code/wifi disconnects forever
-have to kill the ST app and reboot the hub to try again
Tried 5GHz and 2.4GHz home wifi.
Tried deleting the ST app from phone (LG V50)
Tried factory reset hub a hundred times
Tried phone and hub right next to wifi router
Tried rebooting wifi router
ONLY thing that works is hub via ETHERNET. Please help???
[SOLVED] Had to install previous ST apk to get wifi working on my LG V50: https://apkpure.com/smartthings/com.samsung.android.oneconnect/download/175021010-APK?from=versions%2Fversion
