@beckwith Looks great.
What about how you actually connected the power to the device though? That’s the main part I’m wondering about.
I get how to open a device and glue or tape the charging coils, etc, but I think I will need some help with figuring out how to connect those to the device’s power input.
@beckwith
OK, so…that is how to get power to the coils in the wall.
What I’m looking for is how to connect the coils that are actually going to be part of the phone/tablet to the phone/tablet.
e.g. For an Android device that does not have Qi wireless charging capability built-in, the only way to get power into the device is through the micro USB port. Then, if you add Qi wireless charging coils to it, how do you get the power from those coils into the device? Do you have to connect them through the same micro USB port, or is there another way of tapping into the device to get the power into it without using the micro USB port?
Also, I’m not asking how to open the Android device. I’m just wondering, once it’s opened up, is it generally easy to figure out how to tap into the power line like my above query, or not?
So you use the existing USB port and the receiving coil is attached to the back of the device. It is very thin and much less obtrusive than you would think.
If you use a different device you have to make sure your USB port is located so the charging receiver is towards the middle.
I tried four models and this is the only one that didn’t get too hot and was small enough to fit into a single gang box. It works great for the Fire because the fire doesn’t require much power. It probably couldn’t handle more “powerful” tablets, but a more powerful tablet seems like a waste anyway.
I’ve had it up for a couple of months and am very pleased with the result.
Let me know if you have any other questions. If enough interest I’ll summarize in a new thread.
If you go with the cheap $50 Kindle Fire it’s easy to open up. Just find the seam and start prying. The back cover snaps right off.
Once inside there are factory test pads for the micro USB on the surface of the motherboard. Just tin and solder a thin gauge wire to “VCHG” and another to the solder point that holds the connector to the mother board (ground). You can figure out the rest.
I would assume as long as you just tap the power pins it’s equivalent to wiring batteries in parallel (same voltage).
You’ll increase the available current but the device will only draw what it needs when charging. There should be no risk of overload if both are connected at the same time.
OK, so the only option is to plug into the micro USB port to give the power to the Android, and there’s not a way (at least as far as you know) of tapping into the power line inside of the device cavity to avoid having to plug into the micro USB port?
According to the post by @mobious, there is a point on the circuit board where you can solder:
I haven’t tried it yet to say for sure. This increases the distant from the charger so it may impact charging efficiency. It also is a more delicate process requiring trimming back some of the plastic on the Qi receiver USB connector. It would obviously void the warranty.
Update: I took the cover off a Fire tablet and put it over the one I made with the Qi receiver on the back and it seems to charge just fine. Thus, I think the extra distance won’t cause an issue.
In my case, they’re not Amazon devices. So, I don’t have that option…well, at least I won’t until I open one of mine up to see if I do Thanks for all of the interaction on this. I love seeing what you’ve done along this route already and I’m picking up good tips on my journey toward doing a better mounting job. Round one so far is just plastic clips to hold the tablet up there with the cable dangling down to where it plugs in. I mean, I’ve tried to hide it if there is anything else present that can run interference, but it’s far from a good, ‘finished’, built-in look.
They are pieces of garbage! I was part of the original campaign on indiegogo…for over 2 years they kept promising and promising and finally delivered a poorly built POS - one of them died after one use. Horrible product!
I came close to buying those but ended up going with SnapPower instead for my chargers (www.snappower.com) when they launched on Kickstarter. I was not disappointed at all! It’s a little different as it just provides a USB port, but it is very handy for renters who can’t go into the wall.
I’m thinking I may put this on my spare 42" TV and have a big screen, touch-capable SmartTiles device when it ships (currently targeted for March, but you all know how tech crowdfunding projects go).
I backed it thinking I might be able to find a use for it eventually. At worst, it was going to be a novelty item.
I got in at the Early Bird price of $99 (and an additional $19 later on for the camera add-on). It’s really the cost of a pair of cheap tablets. If it works, it’ll be awesome. If it doesn’t, at least it wasn’t the cost of their other device, the Pond (Touchscreen Projector retailing for $599).
Any thoughts here? Trying to change the “inactive” state of this button to also be a christmas tree. The active state shows as a christmas tree, and the title color change also works.
