Hi all,
I see that Smartthing specs its working temperature as from 0 to 40 degree C. So, what happen if the ambient temp goes highger or lower than that limit? whether it will turn off itself or just left it running?
Hi all,
I very much doubt that it has an automatic shutdown.
The temperature specifications are only a recommended range; outside of which the unit is more likely to malfunction or hasten deterioration and component failure, and perhaps even risk of fire or electrical hazard.
That is the recommended temperature range at which the device is stable. Anything outside that range and behavior is unpredictable.
I have a dash dam that has specs from 0 to 40 C. When it is below 0 C the camera is flaky, but doesn’t fail permanently.
Stable? Yes, on February 29th.
Otherwise you can expect failings all time even at 25C
