SmartThings won’t set ecobee threshold
I changed my ecobee heating/cooling threshold to 4 degrees on the thermostat (default is 5). For months, SmartThings had no issue then setting the range from 70-74. Recently however the thermostat is forcing the 5 degree default. I checked the thermostat settings and it still says 4 but when my automation kicks off the thermostat range is forcing the 5 degree range again. Any ideas what’s up?
