SLKDK
July 6, 2016, 12:39pm
1
Hi, just got a UK version V2 hub.
I have EU plugs so I am in need with an power adapter. However, I was wondering, can I power the V2 over its USB ports?
Or does it support POE?
ghesp
(Greg)
July 6, 2016, 12:59pm
2
I don’t know for sure, but I would assume that neither of those are supported.
It looks like you have options.
Okay, ST v2 hub powered by PoE, it works
So I was just going to dump this all in and let you all fend for yourselves but in the interests of you not blowing up your hub I feel I should do a little bit of an explanation. Usual disclaimers apply, this is NOT supported and there are no guarantees it will work at all. I’m NOT responsible for any loss or damage to any property or data. At this point I have openly admitted to ST that I have used a power supply other than the one they give you with the hub and I accept that in all likely hood that if I have any issues with my hub, ST will tell me to go and pound sand and they have every right too. If you choose to attempt this as well you MUST accept this risk.
Firstly there are a couple of ways people do PoE and they are what I will ca…
