Smartthings Routines with Samsung S90C TV
I’m using a Samsung S90C TV and an Aeotec SmartThings V3 Hub. The TV has software version 2202.0.
My problem, is that routines that rely on the selected input on the TV, no longer work. Only turning the TV on and off is recognized as a trigger, but not the inputs. The SmartThings app correctly displays which source is currently selected, but the routines don’t seem to recognize this anymore. I’ve tried everything: deleting and re-adding the TV, recreating the routines, but nothing works. I can test the routines manually, and that works—it’s just the triggers that aren’t working. It seems to me it’s a SmartThings problem.
No idea from anyone?
Are you able to select an input as a trigger? Can you post an example of a Routine that is not working?
